Question about Panasonic DMR-E50 DVD Recorder
Will only read one of my maxell lense cleaning discs. No other discs.
  • jimluzzi Oct 02, 2009
    After opening the recorder ( with the power off, hehe) how do I open the black disc cartridge assemble to get to the lense?
  • 10,515 Answers
  1. Check the disc you're using for scratches and dirt. If the disc is damaged it won’t play properly, regardless of the DVD player’s ability to function. You can use a DVD repair device like the "Disc Doctor" to repair the DVD or purchase a new DVD.
  2. Make sure the discs you're using fit the correct format specified by your DVD player. For example, if your DVD player doesn’t support home-burned DVD-R's, then you can’t use a DVD that you made at home. You may need to upgrade to a newer model, most of which accept the latest DVD formats.
  3. Clean the laser lens with a DVD laser lens cleaning disc. DVD laser lens cleaning discs can be purchased at most electronics
    retailers or online. Insert the laser lens cleaning disc and follow the instructions.
  4. Insert a correctly-formatted, undamaged disc into your player. Listen to see if it begins to read the disc. If it continues to make no sound and gives you the same message, then the problem is probably that your disc is not spinning in the device.
  5. Turn the device off and unplug it. Take off the outer casing by removing the three or four screws and lifting the top piece off. This will allow you to see if anything is simply stuck or jammed. If this is the case, a simple nudge back to the correct position will fix the problem.
  6. Clean the lens while the DVD player is open. A dirty lens is most likely the cause of your no-disc error. The lens should be cleaned with isopropyl alcohol and a cotton swab.
If none of the solutions worked, then you need top open the DVD player.
There is a nice repair article :-
http://www.hungryhacker.com/articles/haxedhardware/misc/dvd_player_repair/
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Do accept the solution, if 100% satisfied from my service!!
Posted on Oct 02, 2009
  • Panasonic Master
  • 19,396 Answers
The lens pickup is dirty or damaged.
If the unit is under warranty call Panasonic at number listed on manual.
If you want attempt an home repair you can tray taking apart the unit and accessing the lens. Of course after disconnecting power. In there you will see the lens pickup. The lens can be cleaned using QTips and isopropyl alcohol.
If that does not work, the lens pickup must be replaced, and that is a repair that must be done by an experienced technician.
Posted on Oct 01, 2009
Lite on burner will write but cant read
Now I LIKE Liteon very much. THey never give me any trouble and as long as you keep the lense clean, they burn for years upon years to come. Okay, so it CAN write, but can't read? Very odd indeed. I would strongly suggest first buying a CD Lense Cleaner disc. Don't be cheap. Get Memorex or Scotch 3M. I would Suggest Memorex because the brushes on THAT disc are SPECIALLY-designed to clean the lense, but NOT to damage it. Next, try installing Nero Ultra Edition and do a Burn-in or a Read/Write test with a CLEAN CD or DVD and see if it will tell you the Read/write data rate. If the lense is just a BIT dirty, it WILL give you those kind of problems.
Mar 25, 2014 | Lite On Computers & Internet
Mp3 files will not burn
No imation brand is known for problems but maxell usually work great i suggest cleaning the cd burner try compressed air can spray out the cd burner with the door open you may have dust on the laser lens...
Feb 05, 2010 | Maxell CD-R 80 Minute 700MB Media...
DVD inserted tries to read disc eventually message says no disc
First purchase disk cleaner disk from nearest computer shop then put it in dvd then play it so it clean dust from dvd lense.
If still it not read disk then you have to change dvd lense.
If your dvd is in warrenty take it to service centre and they replaced lense and repair it.
Let me know if you need more assistanse.
Thanks.
Sep 07, 2009 | Televison & Video
Xbox Mech assault 2 lone wolf Limited Edition wont start
have you tryed actualy cleaning the xbox lense by running a lense cleaner ? your supposed to clean any lense that reads discs after every 10 hours of play time because of the dust thats getting collected .
Jul 22, 2009 | Microsoft MechAssault 2: Lone Wolf
Kenwood 6 disc player says no disc
Hi
The drive is not reading the disk properly. This is either caused by a fault in the laser/lens/drive itself which is leaving the laser misaligned and unable to read the disk or it is caused by dirt in the drive effecting the lens.
There is a Laser cleaning DVD that you can purchase from any audio shop - its not expensive and useful to have around anyway. I would recommend you try a good qulity one such as this from Maxell http://www.amazon.co.uk/Maxell-Europe-Ltd-CD340-Cleaner/dp/B000001OM5
You may find that this will resolve the problem as a simple and quick fix.
If the cleaning disk does not work then the unit will have to go for service repair
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 21, 2009 | Kenwood KDC-C467FM 6-Disc CD Changer
I have an ilo dvd ro4 and when I put a disc in it says invalid disc
Laser is either dirty or starting to wear out.It may also not be a compatible disc,not all brands of discs work in this model.The unit records on R+Rw+ discs 4x speed or slower.Variable speed discs1x-16x will also work.
Most of the time it is just a dirty laser that can read the disc,to clean laser use a commercial laser cleaning disc,Phillips and Maxell work well in this model.Put a drop of rubbing alcohol on cleaning brushes.
Jul 06, 2009 | iLO DVDR05 DVD Recorder
Unit plays DVD but no longer Blu Rays
That is because of a dirty or defective lens. When lens is dirty, the unit may still operate on regular CDs and DVDs and not be reading BD.
Try first using a lens cleaner for Blue Ray: Maxell 190054 Blu-Ray Lens Cleaner
If that does not work, the unit may be disassembled, and lense cleaned with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
Being this a blue ray unit , I would suggest calling support instead of disassembling the unit by yourself.
Regards
Feb 08, 2009 | Samsung BD-P1400 Blu-Ray Player
Blank disks won't record
FIRST HAVE THE LASER LENS CLEANED
THEN USE MEMOREX DVD-R THIS SHOULD SOLVE YOUR PROBLEM
Oct 20, 2007 | Panasonic DMR-E50 DVD Recorder
Problems with dvd reading
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Jul 21, 2007 | Cyberhome CH-DVR1500 DVD Recorder
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
Panasonic DMR-E50 DVD Recorder Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
