Question about Whirlpool Duet GHW9150P Front Load Washer
Moldy smell always tried bleach and vinegar. Use
Washer smells moldy and causes clothes to smell moldy. Hot wTer makes it worse. Use he detergent as directed. Have tried vinegar and bleach Leave door open nothing works.
  • 725 Answers
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Posted on Oct 01, 2009
  • shinything13
    shinything13 Mar 11, 2012
    I want to know why Frigidaire sends technicians out and say there's nothing you can do about it, but Whirlpool recommends a new gasket....looks like I bought the wrong brand!!!
Moldy gasket
It because the mildew is not just on the gasket, but it is in the tub and in the pump and discharge hose as well. You need to reduce/eliminate the mildew in those parts. There is a couple of things you should do to reduce the causes of mildew.
1. Run the machine once a month using hot water and two cups of vinegar to clean out the machine. You might need to repeat this a few times to completely clean out your machine.
2. Follow the manufacturer's instructions for the about and type of laundry detergent to use with your wash. Using too much detergent causes a build up of detergent on the tub which encourages mildew growth.
3. After your final wash of the day, leave the door and laundry detergent open, wipe dry the gasket with a cloth.
4. If the above steps does not help, try a commercial product like Affresh.
Hope this helps you.
Jul 22, 2010 | Frigidaire GLTF2940ES Front Load Washer
Top loader smells like mold. Maytag washer canot rid the moldy smell. Spray with bleach and after a day it smells bad again
you must use liqid soap ? what you need to do is add 1 gallon viniger to a small load all hot water let wash 4 a min or 2 let stand over night start back up and you should be good to go when you put in your soap when washer adgit. or swith to powder
Feb 14, 2010 | Maytag Washing Machines
My washing machine smells moldy all the time. I
run a cycle with bleach only. nothing else in it. no close or nothing. there might be a problem with your draining hoses. they might not be draining quickly enough. might i suggest you unhook them and make sure there isnt any water in them. please rate my solution
Sep 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell
try running it throgh a cycle with nothing but hot water and bleach let set for a couple of minutes between cycles with water in it may have to do a couple of times
Mar 29, 2009 | Whirlpool LSB6200KQ Top Load Washer
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Moldy smell in front load kenmore washer
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Moldy smell in washer
run cycle using bleach only in water after cycle use a bleach/water solution to thoroughly wash door seal be sure to pull seal at bottom of drum opening and clean inside lip in future leave door open as much as possible between cycles just remember YOU ARE NOT ALONE..all front loaders no matter the brand have same issue some just worse than others
Jun 18, 2008 | Kenmore Elite 45986 Front Load Washer
Disgusting odor
I had the same problem, except it wasn't just towels. It was everything. I did some research and found that this is a common problem and nothing a tech can fix. I was about to go out this weekend and spend $1000 on a new washer because I couldn't use this washer on my clothes anymore. I did one more search for a solution and THANK GOODNESS found a solution on another site. A woman had the same problem and, after much trouble, someone at Best Buy finally told her to never use liquid detergent in the machine, not even HE. So I cleaned the inside of my machine, around the door, the rubber seal, etc. I ran the tub clean cycle with bleach and vinegar. The smell was gone and I have been using powder Tide ever since, and the smell hasn't come back!!!!!
Mar 12, 2008 | LG WM2688H Front Load Washer
Have you tried using detergent HE (High Efficientcy) for front loaders? I had this problem and changed over to HE Detergent (Tide) and it solved my problem. Good Luck
John 3:16
Dec 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
479 people viewed this question
Dan Webster
Dan Webster
Sal De
