Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Side by side amana freezer will not shut off.
    President:
  • 744 Answers
Hi, this problem is going to be with the running thermostat (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Posted on Oct 01, 2009
Amana side by side fridge makes a groaning noise when freezer is shut, no ice buildup nothing, just groans when light button is pushed
When light goes out, fan starts inside. Groaning sounds like the fan is hitting on something or has a dry bearing. Spray with wd40 on the shaft
May 01, 2012 | Amana Refrigerators
Freezer down won't stay shut model # ARB220ZCC
I called Amana and they would send me a part for $77 but they weren't sure it would solve the problem so I purchased a bungie cord for fifty cents that holds the door shut. It is a bit inconvenient but it workis for me!
I am thankful that Amana doesn't make autos!
Feb 24, 2010 | Amana Freezers
Have an amana side by side refridge. freezer will not shut off
bad thermostat
it is up behind the controls
make sure the other side is clear
its behind a plastic dome on the right hand side of the freezer, upper next to ice machine....
take off the cove and make sure there is not ice in there...
if not its proibably bad and should be replaced
Oct 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
The freezer is cold but not cold enough to make ice
Check the back (interior) lower half of the freezer wall. If you see a frost build up, you either have an issue with your defrost cicuit (timer, heater, thermostat) or the evaporator (freezer) fan is not running. If there is not a frost build up on the back wall you either have a sealed system (weak compressor, leak or restriction) problem....or the condensor fan motor is not working. This would cause the compressor to overheat and shut down until cooled, and prevent the deep freeze.
Jun 05, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana Side-by-Side Refrigerator Not Cold
can be a few things, if you open the freezer door do you hear afan running?? perhaps the fan is no good?? is there a large amount of frost on the lower plate of back wall of freezer??? very common issue to have a bad defrost thermostat.
Feb 19, 2009 | Amana ARSE66MB Side by Side Refrigerator
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Fridge and freezer not cooling properly!
Sounds like a problem with defrost system , It could be one of there components , timer, heater, or defrost thermostat. try advancing the timer, down at the lower area behind the grill. with a screw driver by putting it into the dial advance and turn it till it clicks and the unit shuts off. now you should see red glow at bottom of back panel in freezer or here sizzling . if this does not happen then it will be the heater or the thermostat.
Apr 27, 2017 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
22 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
