Question about Sport & Outdoor - Others
Have a 97 mxz583,getting oil out exhaust,problem?
  • 29 Answers
HELLO;It sounds like you have one of two problems, one your over filled with oil or you have a valve or ring problem.
Posted on Oct 02, 2009
97 f350 7.3
is the turbo getting oil to it? or does it have a exhaust leak to the turbo?
Jan 29, 2014 | Cars & Trucks
I have a 97 Chrysler Sebring LX with 132,000 miles. I lose about a quart of oil every 3 weeks and have smoke coming from my exhaust pipe. After about an hour of letting it idle it will stop smoking. I...
Smoke from the exhaust at start up means that the valve seals are leaking oil into the cylinder, smoke when you accellerate means that the piston rings are leaking oil.
Jan 06, 2014 | Chrysler Cars & Trucks
My 97 Neon has white oily substance in radiator
Hi it sounds your head gasket need's replaced ,,,As for the water creamy white that means that oil is getting in to your water .
The head gasket has gone water can get into oil
but it also oil can get into water can also
water can be lost down the exhaust.
Replace head gasket clean out radiator
Jul 30, 2013 | 1997 Dodge Neon
My 97 civic lx is leaking oil from the exhaust. I recently had the timing belt and distributor replaced but it continues to build up an oil mist on the rear bumper. The gas mileage has dropped...
I would pull the spark plugs and see if they have oil on them. If so, I would have to say that you have BLOW-BY. In other words the piston rings on your pistons or the cylinder walls are worn. When this happens oil can blow-by the piston rings into the combustion chamber. So as the exhaust opens up the oil is flowing through it and into your exhaust. This can be a very expense repair.
Jul 26, 2011 | 1997 Honda Civic
Does a 97 dodge ram 1500 have an engine to firewall ground strap and if so can you describe the whereabouts?
My '97 with the 5.9L gas engine does not. It's grounded from the battery to the frame and a ground strap ran from a bolt under the exhaust manifold on the passenger side(near the oil filter) to the frame
Nov 01, 2010 | 1997 Dodge Ram 1500 Club Cab
97 f250 5.8L starts to run rough and puffs out thick black smoke. It comes and goes. Any ideas?
Exhaust problems. Black smoke=exhaust, blue smoke=oil, white smoke=water.
Aug 05, 2010 | 1997 Ford F250 SuperCab
97 kia sephia smokes when first starts, smells like exhaust smoke
Black smoke is fuel.
Blue is oil.
White is coolant / water.
Fuel is caused by timing and cold start system and requires some discussion to clarify.
Oil burning only on start is caused by failing rings on your cylinders. Oil then enters the combustion chambers and burns when you start the engine. If it continues to burn when running in particular when you accelerate it will also indicate ring/cylinder failure. It can also be from a failing head gasket where oil travels from the lubrication system into the combustion chamber. Some of the anti smoke additives available at the auto supply store do help.
I doubt you are seeing white as you say is smells like exhaust. White is coolant in the combustion chamber or exhaust system.
Hope this helps you.
Mar 11, 2010 | 1997 Kia Sephia
Oil in exhaust
sounds to me like you have a piston seal going out. if your mechanic savey you can take the exhaust manifold off and find the piston that is leaking and fix it your self if not i suggest taking it to the dealer. might be expensive.
Jan 12, 2009 | 1997 Dodge Ram 1500 Club Cab
Sport & Outdoor - Others Logo
18 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
