Sony KV27EXR15 picture has an hour glass shape
  • 2 more comments
  • bweddings Oct 02, 2009
    Sony KV27EXR15 has an hour glass picture
    VinayT,
    What coponet is most responsible for this condition.
    VinayT,
    What is the procedure for setting it.
    President:
  • 1,884 Answers
It is known as pin cushion effect. there are settings for this. You can set it right from the Menu.
Posted on Oct 02, 2009
  • Vinay Tevatia
    Vinay Tevatia Oct 02, 2009
    There are no components involved. It is the settings that have to be adjusted. It happens in computer monitors too. And sorted out with the on screen display settings menu. So would it be in your case too.
  • 5,138 Answers
I will have to do some checking but im sure you have a bad capacitor i will be back in touch with what you will need to do to fix this problem. most of the time it is a bad capacitor or A doide that just need to be resolder.
  • ladywinn
    ladywinn Dec 11, 2009
    Diode or Capacitor 47uf 250v is what causes this!
  • ladywinn
    Diode is a NTE577
    President:
  • 1,922 Answers
Your flyback transformer on the deflection board in beginning to get shorted windings inside unit
  • 615 Answers
It sound as the sleep timer is on and not resetting. Do you have the manual to follow up procedure for resetting?
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
  • 10,515 Answers
This issue is the scan correction or East-West control
You see as the set tube gets bigger so their is a greater need to control the scan
This is achieved by incorporating an East-West correction circuit and its here where the fault lies
You have dry/cold joints in this area which may have got that poor a contact that it no longer makes
Also the poor joints could have damaged the transistors or loading coils in that area too
Its a none do-it-yourself, i am afraid due to the job being done right first time otherwise if something is overlooked it would lead to the new devices failing again!
A technician would probably charge $90-$100 for this repair
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 01, 2009
  • taran_2005
    taran_2005 Oct 02, 2009
    Thanks for your response!!
    Still, if you want to DIY at your own risk, you can purchase a Service Manual from the link below :-
    http://www.user-manuals.com/advanced_sea...
    Hope i helped you.
    Do accept the solution, if 100% satisfied from my service!!
The picture on my Sony is shaped like an hour glass
There is an apparatus on the back of your picture tube called a yoke.This distributes your picture on your pic tube uniformly.If this or the circuits enabling it malfunction,then you will get distortion-namely an hour glass shape.Tv has to be trouble shooted.
Feb 27, 2011 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony kp-61s70 hour glass shape on picture bows in
the sony service menu can be entered by pressing "display" "5" "vol+" also the diagnostic screen can be reached by vol- instead of + when you are in the service menu the number buttons navigate it its a little tricky at first but as long as you dont hit enter before you exit if you mess up it wont save just make sure if you fix it you save it by pressing enter
Jul 13, 2009 | Sony KP-61S70 61" Rear Projection...
Sony 32
It more like the tuning capacitor(s) that is connected to the HOT that is defective or a cristalized/dry solder joint nearby the flyback transformer.
May 30, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Mitsubishi WS-55807 hour glass shaped picture
If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual and try by yourself see link
Mar 04, 2008 | Mitsubishi WS-55807 TV
Tv screen has slight hourglass shape
A common fault are some of the electrolytic capacitors failing in the pin cushoning amp section, and probably in part of the scan amplifiers.
To service this will require the proper training and set-up to troubleshoot the set.
Take the set to a service center for an estimate. The cost can be at least an hour or two for the labour, and then the cost of the parts on top.
Jerry G.
Nov 06, 2007 | Sony KV-32S26 32" TV
Hour Glass Picture
can you put it other way i did not understand what you want to say & que is not complete.
Sep 25, 2007 | GE 31GT660 TV
Shrinking picture
picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Sep 22, 2007 | Televison & Video
Tv picture shaped like hour glass
Big cap in the regulation ckt is bad. Depending on model could be various values, a shop could use their ESR meter to find and replace it.
Jul 03, 2007 | GE 31GT740 31" TV
Picture shaped like hour glass
You have a PIN CUSHION problem, is usually a bad capacitor or open resistor in the above cicuit. Check all the caps around the horizontal output transister for ESR leakage.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Televison & Video Logo
270 people viewed this question
Top Televison & Video Experts
Electro Med Services...
