Question about Samsung SGH-J600 Cellular Phone
Where do I type my message code to get my message
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Dado
Mar 31, 2015 | Asko TL751 Electric Dryer
Tip
Instructions for Unlocking BlackBerry phones ( All Models)
<span><span>Always the Best way to Unlock Your Phone is by using the MEP2 code or Unlock code. First you should<a href="http://unlockgenie.com/"> Purchase the Unlock code from a Trusted Vendor.</a><br /><br />After u got the code follow the instructions below......<br /><br />BlackBerry Unlock Instructions (9800)<br /></b><br />* Insert a foreign SIM Card<br />* Power on the phone<br />* When prompted, enter your unlock code<br /><br />BlackBerry Unlock Instructions (83xx/85xx/88xx/8900/9000/9300/96xx/97xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />BlackBerry Unlock Instructions (95xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Tilt the phone horizontally, click the BlackBerry button and Show keyboard<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />o *If MEPD doesn't work, try MEPPD<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />o *If MEP2 doesn't work, try MEPP2<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Blackberry Instructions (81xx/82xx/9100)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Old School BlackBerry Instructions (87xx & Older)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Hold ALT key and type 'MEPE' (user will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked</span></span>
on May 05, 2011 | Cell Phones
I sent the messages to any number it shows text message al ready in use
You can do master reset which can fix these types of problems. The code is 5011615732 or try *#7370# and then type 12345. If these codes do not work, contact nearby service center.
Nov 03, 2010 | Nokia N72 Cellular Phone
I need the configuration code for a stairmaster 7000 pt. it just says config req. It has done it before but I cant find the code again. do yo know the code?
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Aug 11, 2010 | Stairmaster Stepmill 7000 Pt
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Webpage error details
100% working IDM fake key block problem
http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Mar 16, 2010 | Microsoft Internet Explorer 8
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; .NET CLR 3.5.30729; .NET CLR 3.0.30729;...
Usually associated with bad java script lines. Is it your coding or coding on a website? Check you are able to activate Java on your browser
Aug 01, 2009 | Microsoft Internet Explorer 8
Cannot Call or MSG
hi friend"s
don't worry,
first go to the"menu" then "setting",there sould be factory setting at last point..click on it..
then u will have question that "restore all original setting?phone will restart. yes/no?
click on yes!!
then u will again ask for passport/security code..
if u change your security code then type it if not then type 12345 as a security code.
then click on ok..
your phone will restart,
and go to setting,phone setting....and coll divert setting,,and voice coll setting,and all voice coll setting.,,and click on cancel...
after try to coll and send sms..
if u have still problem on sending sms,....go message click on the message setting....then click text message setting..
there soule be message center click on it and type ur message center no... and came 1 step back and click on message center in use,,,choose that message center u type .....you can get your message center no fron ur sim card priviver,,,otherwise u can copy that message center no. from ur friends cell ,....that message center no. is located at same place on message setting...but ur friend's sim card sould be same with your's..
wiss my sugesation will great for your phone
Nov 11, 2008 | Nokia 3110 Cellular Phone
Samsung SGH-J600 Cellular Phone Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
