Question about Whirlpool Duet GHW9150P Front Load Washer
What does f and dl mean on a duet whirlpool washer
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Posted on Sep 28, 2010
Dl f error code kenmore 11045081400 washer. what does it mean?
Here is a youtube video , you code has to do with door lock assembly ! Troubleshooting and Repairing an dL Error Code on Whirlpool Duet Washer . your washer is the same as this . Kenmore is built by whirlpool !
Feb 27, 2015 | Kenmore HE2 Plus Front Load Washer
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
I trried to start washer and a code dl came up
dl means there is a problem with the automatic door locking mechanism that engages before the wash cycle is started
Jul 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting message F DL. ASSUME MEANS DOOR NOT
IT APPEARS YOU HAVE A MAGNETIC CONTACT FOR THE DOOR,YOULL HAVE TO HAVE A REPAIR MAN REPLACE THAT CONTACT,
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing codes
you have a communication problem between your door lock and your ccu board. Are you hearing a click click click before it fails? If so this is a relay inside your ccu board. Replace the board this will solve your problem
Jan 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer code
Hi Keitha1
I'm Harvey the Master Plumber
You want to know what code dL means on a whirklpool duet washer.
This is what works for me 99% of the time:
Simply unplug the washer for ten minutes. The onboard computer will reset and work like new.
Please understand that you are not being shortchanged. There are hundreds of codes and with this new computer tech. they mostly require a repareman. To save you money the manufacturer has designed it to reset itself after ten minutes to solve most problems. Try this first, you can always call a local pro later if you want.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
44 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
