Question about Toshiba 50HP66 50 in. Plasma Television
I have snow, colored at some times. Goes from light to heavy.Not so bad that you cant enjoy the tv but when the screen has alot of dark colors to display you can really see it. Does not matter what input I am using. The screen is totally black when I turn on the set then as soon as the tv sends a signal to the screen i get the interference. I just bought the service manual for the set and can not fin anything close in the troubleshooting guide. PLease help!!!
  • molidorjohn Oct 02, 2009
    it seems there has to be someone else out there with the same problem.
    It seems that the issue gets worse the longer the TV is on. I also think I noticed a correlation to electrical devices being on in the apartment.
    This is not a signal related problem.
    Same issue regardless of DVD via HDMI, SAT via S video or Playstation 2, via componet video inputs.
    It is more prevelant in the portion of the screen that is always in use. very little at the top and bottom of screen that are not in use as much.
    President:
  • 1,714 Answers
I suspect that the TV is not the problem and that you may have a bad signal with noise coming through. Have your cable provider check the line.
Posted on Oct 02, 2009
    President:
  • 1,884 Answers
It generally happens when the video signal is poor in quality. the poorer it is the more snow you get. you can also get snow if the fine tuning to channels is not perfect. the farther away you are from the perfect tuning, the more snow you get. Since it is on all the channels from all the inputs, I presume it is poor signal quality may be due to a poor quality or faulty connector/cable.
    President:
  • 2,187 Answers
To ensure that this is not interference, you can have the tv moved from its location and isolated from other equipment or appliance in the house and see if the snow or problem would disappear. At times this may be attributed to signal or low signal problems. This can also be caused by voltage problems. You may want to check the power supply if there is any leaking capacitors or loose parts there. Some TVs can have the voltages adjusted. See if you have one but do at your own risk. If these does not work you may have a problem with the plasma display panel which will need replacing.
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Digital Lifestyle LT32323 screen color keeps going red
Try changing the input device to something you are sure, works such as a DVD player. Look for any loose contacts in RC jacks/sockets/Cable.
Aug 05, 2012 | Digital Lifestyle s LT32323 LCD TV
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
Poor picture no color
OUCH! LARGE DARK SPOT IN CENTER IS NOT GOOD FOR PROJECTION TV. YOU BURNT THE TUBES. THE LOSS OF COLOR IS THE ROOT CAUSE SOUNDS LIKE A DEFLECTION CIRCUIT PROBLEM. THE TIMING FEEDBACK IS USED TO SYNC THE COLOR CIRCUIT. IF THE TUBES LIGHT WITHOUT DEFLECTION THEY BURN THE CENTER PHOSPHOR COATING INSIDE.
Dec 24, 2009 | Televison & Video
Dark Color on TV. Can't adjust the color correctly
Having same problem now for a second time on a 57T500. First time was a bad green bulb that was covered under warranty. Only lasted 2 years....currently debating wether to fix or buy a new set. Bulbs cost about $300. Set is only 5 years old, so very dissapointed with quality.
Feb 01, 2009 | Hitachi 57F500 57" Rear Projection...
When tv warms up i get red dots in darker areas of screen
what you can do is take off the back pannel and there is a cord on the top of the board that looks like a computer board, there are many boards in the TV but the one I am talking about is twords the bottom where the video jacks plug in to the TV. Ok once you have located the pannel there is a cord on the top kinda tword the right side, it is many wires inside a black covering. What you need to do is just simply unplug it and plug it back in, do this as many times to try to get it to fix the problem.
Dec 29, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
Toshiba Plasma 42
plasma42 color flickers in and out and now its just snow,now its black screen. still have sound.please help me.. what board should i replace??
Dec 29, 2008 | Toshiba Televison & Video
The picture on my 2 yr old Toshiba 42hm66 DLP tv starts flickering and with alot of rainbow looking distortion after an hour of veiwing. I replaced the lamp, but it sill has the probelm. Any idea what...
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
Dec 02, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Bad colors and snow
does it have a fan on card if so is it working or is heat sink etc blocked by fluff and dirt if so clean it try again. this sort of thing happens to cpu,s as well I regularly remove and clean fans and heat sinks
Jul 17, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
Toshiba 50HP66 50 in. Plasma Television Logo
75 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
