Question about Olympus FE-360 Digital Camera
Flash wont work.. shows the motion detect "little red lightning bolt" even if the camera is perfectly still the flash wont work.. Olympus Fe-360
SOURCE: Olympus FE-115 : wont turn on..turns iself off!!!
I've experienced a very similar problem. I took our camera to a Bridal shower with 2 sets of freshly charged (I validated the charge) NIMH rechargeables plus a set of new alkalines. Regardless of which batteries I used, the camera indicated low battery after one or two pictures were taken, if it would take one at all. Its NOT a battery problem in my case.
Posted on Jun 14, 2007
Coldcut
  • 1554 Answers
SOURCE: Flash not working
The flash tube or the circuit could be burned out as it is fairly high voltage.
if the tube is black then its blown
Posted on Mar 25, 2008
  • 919 Answers
SOURCE: Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
Posted on Jan 13, 2009
  • 919 Answers
SOURCE: how to connect my olympus fe-360 cam. to laptop as webcam
Unfortunately this camera is not capable to be used as a webcam. It is only to be connected to the computer when you want to download images from the memory card to the computer.
Posted on Mar 09, 2009
  • 70 Answers
SOURCE: Camera is freezing on one setting
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Posted on Mar 23, 2009
How do I turn off the flash on my Olympus FE-190?
Press cursor-right (marked with a lightning bolt), then select the desired flash mode. To turn the flash off, select the lightning bolt in a circle with a slash through it.
Full details are on page 17 of the Advanced Manual. If you need a manual, you may download a copy from here.
Dec 22, 2012 | Olympus FE-190 Digital Camera
FE 20 turn off flash
Look for the flash button (looks like a lightning bolt) to cycle through the flash options. Flash options can be limited in AUTO Shoot mode.
The manual describes how to use the Flash on page 19 of the manual.
You can download the manual here http://www.olympusamerica.com/files/oima_cckb/FE-360_X-875_C-570_FE-20_X-15_C-25_Instruction_Manual_EN.pdf
Mar 13, 2011 | Olympus FE-20 Digital Camera
The flash does not work even if the flash setting is SET to FILL ( the flash will work every time the camera is in used) I already tried to reset the settings to default but still the flash wont...
Does the camera indicate that the flash is turned on? In most olympus cameras I have seen there is a lightning blot at the lower left corner of the screen. Verify that it is indeed there and let me know.
Aug 18, 2010 | Olympus FE-170 Digital Camera
How do I turn the flash off?
Press right on the multiselector (marked with a lightning bolt). Use up/down to select the flash mode. Your choices are Auto (blank), Red-eye reduction (eyeball), Fill-in flash (lightning bolt), and Flash off (lightning bolt in a circle with a slash through it).
Don't forget to turn it back on when you're done.
Jul 12, 2010 | Olympus Stylus 710 Digital Camera
I don't now how to take flash off on my camera which is a olympus fe-100
Push the button with the lightning bolt icon until a lightning bolt with a line through it appears on the screen.
Mar 20, 2010 | Olympus FE-100 Digital Camera
How do u turn off the flash on the olympus fe-170? im going to a clapton concert tonite and i need the flash to be set to off i tried everything and i cant turn it off....please help!...thanks!
Press Right-arrow (marked with the lightning bolt) repeatedly to select the flash mode. In this case, you want the lightning bolt inside a circle with a slash through it, indicating "no flash".
After the concert, don't forget to set it back to Auto, or the flash will never fire again :-)
Feb 25, 2010 | Olympus FE-170 Digital Camera
The flash does not work and shows a red lightening bolt in the viewfinder. I can still take pics without the flash needed
Two possible causes: 1. Your battery is weak. 2. You have the flash turned off. Press the button with a picture of a lightning bolt and watch the screen to see if it changes. Stop when you see the bolt and an "a".
Feb 04, 2010 | Olympus Stylus 710 Digital Camera
I cannot get the flash to work???
the flash is a pop-up mecanizem. on the left side by the neck strap ring, theres a little button. that button should pop the flash up. and there ya go. on some settings the flash doesnt work even with the flash up. on the screen, when its on theres a little lighting bolt, when theres a line through the lightning bolt, that means flash is off, when you have it on the AUTO setting and its fairly dark out, and the flash is up, it should automatically be on. anytime you see that lightning bolt on your camera, its related to flash.
Jan 31, 2010 | Fuji FinePix S1000FD Digital Camera
Red flashing lightning bolt on the screen
That is the flash charging indicator blinking constantly on the screen. Unfortunately the camera will need to be sent to Olympus for service as this is a switch inside the camera that needs to be replaced. I would call Olympus Customer Service for repair process and pricing information. Their telephone number is 800-622-6372 option 2 and then option 3.
Nov 21, 2008 | Olympus ? Stylus 500 Digital Camera
Fe-100 wont come on
use external 4.5v npkia battery. huh. ı have same machine and hate olympus.
Jun 26, 2008 | Olympus FE-100 Digital Camera
Olympus FE-360 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
