Question about Frigidaire FTF2140FS Front Load Washer / Dryer
How do you check if the coin catcher is plugged on a frigidaire ftf2140fs0 washer?
    Problem Solver:
  • 4 Answers
Remove bottom pannel. you will see a black rubber boot.Undo the clamp that connects to the tub. Pull boot down a little and reach the top of the boot with fingers and pull out plastic coin catcher. Clean out and replace.
Posted on Oct 21, 2009
Did not have to remove the front. To get at the coin catcher, just remove the lower cover with two scews.
Posted on Oct 05, 2009
Where is the coin catcher on a frigidaire front load washer?
Good Afternoon Friend,
I understand you want to know where the coin catcher is located. The coin catcher is located inside your washer, at the bottom right-hand side, attached to the drain pump. If you want to get to the coin catcher, I suggest contacting your local authorized technician for assistance. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FTF2140FS Front Load Washer /...
My washer will not drain
Be careful about removing the main hose on the sump. It contains a coin catcher. The small hoses are a bear to get back on there. Try and remove the **** from within without disturbing the smaller hose. SERVICE MANUAL
Jul 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
GETTING ERROR E2O
This is a slow drain problem; remove the lower front panel, remove the pump and clean out the pump and the coin catcher and it will be fine. To access, remove the two screws at the very bottom of the bottom panel and push down and remove , the pump sets just inside.
Hope this helps.
Jun 12, 2011 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain, burning smell on rinse cycle. appears to be spinning just not draining
Check the 'coin-catcher'. It's a small compartment in front of the pump. It's supposed to catch all the big stuff (coins, nails, screws, etc) before it damages the pump. Sometimes lint and other items will snag in the coin-catcher and clog it up... Once it clogs, it will not allow enough water to go thru to drain the machine. I would not use the machine until I got it fixed (or looked at by a repairman)... the smell you're getting could be the pump not getting enough water thru and burning itself up....
Apr 12, 2011 | Washing Machines
I am trying to find a part number for my Frigidaire Front Load Washer - Part No. FTF2140FS0. Can you help? the plastic door latch (I think it's called the Safety Door Lock) has broken off. We can't find...
Alisa hi hun this is shonna neeley out of ohio i just recently had same problem u did and had heck of time trying find parts for my washer is the same as your i will give you the link where to go to order your parts for that washer it help me out greatly when i went there been buying there every since anywhooooo help is on it way doll.
Replacement parts in Cabinet/top section of FRIGIDAIRE FTF2140FS0 Frigidaire/washer
copy and paste this let me no if it helps i,m on facebook as shonna neeley if you need my help cause i strugled getting help from anyone / on my washer and dryer..
Dec 13, 2010 | Frigidaire Affinity ATF7000ES Front Load...
COIN CATCHER LOCATION
I can help if you have a clear mind and patient it will take about a 1 hour.
Jan 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer wont spin
either a bad motor control board or your coin catcher is full of stuff. i would check the coin catcher first. open the front panel and you can see the pump the coin catcher is the part that comes from the bottom of the tub to the pump.Careful when you take it out there will be water in it and you will have to be ready with a towel or shop vac. put it into drain first before taking apart. it will not drain all of the water.
Oct 31, 2008 | Washing Machines
Washer not working
either you have stuff in the pump coin catcher or motor control board is bad.
Apr 19, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire FTF2140FS Front Load Washer / Dryer Logo
681 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
