Question about Garden
Will not start, very weak spark,cannot pull start rope all way
  • 45 Answers
SOURCE: Husqvarna Chain Saw Rope Pulls Very Hard, what is the cause?????????
Has it always done this or has it developed?
Some saws have a decompression button to make it easier to pull over.
Posted on Oct 07, 2008
scott586
  • 41 Answers
SOURCE: Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
Posted on May 19, 2009
  • 6 Answers
SOURCE: wont start
frist thing did you check the flywheel key, if it is sheared its out of time, it will pull back hard .
Posted on Jul 08, 2009
SOURCE: cant pull the rope but when you take the spark
i have cs 30.
string cord won't come out when i pull cord.
when i was using weed eater last night, it just stopped coled.
any iedeas from anyone?
Posted on Aug 24, 2009
dontbother10
  • 2220 Answers
SOURCE: starter rope will not pull. Will pull smoothly
If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
Lou
Posted on Sep 17, 2009
Testimonial: "cheers"
Weak spark at spark plug
You should get a spark that will jump 3/16". Anything smaller will most likely be insufficient.
Sep 20, 2014 | Garden
Intermittent and weak spark
Is the new ignition module gapped right? Are you using a spark tester or just trying to hold it to the cylinder while pulling the rope? If the module sparks then it most likely is not a spark issue. Make sure you have fuel to the cylinder and that the compression in the saw is good. The easiest way to test a fuel delivery issue is to pour a Small amount of fuel right in to the carburetor and try to start it. It should run on the fuel you put in then die if it has a fuel issue.
Dec 17, 2013 | Husqvarna Garden
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
Compression lockup
Remove spark plug. Pull rope several times to blow out cylinder. Spray WD 40 in spark plug hole. Pull rope several times. ensure compression is present. Replace spark plug with new one. Spray starting fluid in cylinder before replacing spark plug. Ensure plug wires snaps on tight. Check oil level, fill with 30w oil if required. All mowers have a low oil start cutoff. Clean or replace air filter.
Sep 10, 2012 | Toro Power Lawn Mower
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
Homelite chain saw XL925 cord pull too hard but if you remove the spark plug then it pulls OK.
I have a Homelite XL and was having problems with rope pulling from difficult to unable to pull rope while trying to start saw. I removed the muffler, squirted some WD40 through the exhaust port ABOVE and BELOW the piston compression ring. Then pulled the rope about 20 times without spark plug to fully lubricate the piston and cylinder. Left it till the next day, pulled it through about 20 more times, put the spark plug back in,and it works well now. Guess it was just gummed-up a little and the lubrication freed it.
Oct 31, 2011 | Homelite ZR10926 16 Chain Saw
Saw feels like it,s out of timing, pull rope hard to pull with plug in.. pulls easy plug out maybe trying to fire to fast
Check the air cleaner for plugging. Remove the spark plug, open the throttle with the choke off, turn the machine upside down and pull it through smartly several times until the excess fuel is expelled. Dry the spark plug interior insulator and test for spark--it should be blue and snappy (plug gapped 0.020"). If weak looking, try a new plug first, and if still weak, remove the left engine case to expose the flywheel and ignition module. Turn the flywheel magnets under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the module gap doesn't close up at any point. Reassemble and test again for spark. If now good, try for engine start. Hope this helps!
Nov 02, 2010 | Poulan Pro Chain Saw 46cc 20"
Turn but not start
if you have spark, then the carberator is plugged, replace it. Pull the spark plug, ground it to the engine, pull rope, whatch plug for spark. if no spark, remove kill switch wire from coil. pull rope agin, if you have spark, kill switch is bad. if stil no spark, you have bad coil.
Sep 24, 2010 | Craftsman 25cc Gas Line Trimmer
Lawn mower won't start
to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Petrol Engine will not start. The saw is a Stilh and I have not usaed it for 18 months
Ok first off drain all fuel out of the saw replace the fuel tank filter, then clean out the air cleaner, pull the spark plug out and with some and paper sand the spark plug so that it's clean. NEXT mix some new gas mix and add to the tank try putting the choke on full and pull rope about a dozen times then put choke in partial open and try starting. If it does not start pull spark plug and pull starter rope and see if you have spark if you do add a capfull of gas mix into the spark plug hole and tighten the spark plug down and try pull starting if it fires off and dies then you have a cracked fuel line and need to replace the fuel line. When you have the plug out spray a small amount of WD 40 into the sparkplug hole and pull the rope a few times to get rings lubracated then add the gas. If it won't start post here and I will give you more directions to test for starting again. HOPE THIS HELPS AND THANKS FOR USING FIX-YA.
Mar 17, 2010 | Garden
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
