Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Have an amana side by side refridge. freezer will not shut off
Just moved it, water is not connected, i tried adjusting the controls they are both set on normal. 4 days and it still will not shut off unless i turn it to 0. also lifted arm on icemaker to shut it off, any ideas???
    President:
  • 1,304 Answers
Bad thermostat
it is up behind the controls
make sure the other side is clear
its behind a plastic dome on the right hand side of the freezer, upper next to ice machine....
take off the cove and make sure there is not ice in there...
if not its proibably bad and should be replaced
Posted on Oct 04, 2009
Ice build up in the freezer
Sounds like your door seals are not seating causing moisture to migrate past the seal and condense and freeze. Check to see if this is true will small strips of paper. If you place the strip in the door and pull, you should have some resistance. If you pull and it moves freely, your door seal needs to be realigned or replaced
Jan 13, 2018 | Amana ARB1905C Bottom Freezer Refrigerator
What should my setting be on for my freezer and refridge be set on.
o freezer side,37ref.,default back to factory settings if possible,adjust slowly,allow 24hrs. to stablize
Feb 25, 2011 | Frigidaire Side By Side Refrigerator 26...
Freezer is cold, refrigerator is warm. sounds
check the fan from the freezer side if its not running /possible frozen or jammed will cause the refridge side to be warm the fan blows the freezer air into the fridge side to cool their is also a damper or duct control which can build up if no blockage or debris test fan for power if power than test fan it self if not running than repair or replace as necessary
Apr 09, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Ice build-up water leak
sheck the back wall of the freezer where it sits in that trough, more often than not this complaint is the fault of a defrost drain. if you can try to remove the back panal on the freezer, if its a defrost issue there willl be a huge amount of ice behind that panal blocking the defrost drain.
after you chip what you can away, you'll find that a hair dryer and hot water are the best way to get that drain clear so it wont happen again
Oct 12, 2009 | Maytag MSD2454G Side by Side Refrigerator
Upper freezer is working but the temperature in the fridge part is approx. 65 degrees -- not cold.
This is a malfunction of the control board. The control board is telling the refridge side that it is plenty cold - so it doesn't divert the cold air needed to keep the refridge side cool enough. Check to see the the coils in the freezer are frozen - if they are, unplug the unit and defrost with a hair dryer. Dry up the water and turn it back on - that should solve your problem.
Aug 22, 2009 | Refrigerators
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
M y refrigerator has turned into one big freezer!
You need to reset the controls to the middle range and alow days for adjustment. If 1-9 set at 5. this wqill take a while to rush leave the door to fridge side open for one hour.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
50 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
