How do you dissassemble the powerhead on a Kenmore Progessive canister vacuum in order to replace...
(More)
How do you dissassemble the powerhead on a Kenmore Progessive canister vacuum in order to replace the swivel?
I need to install part #PHP-236/C45ECUE. This is the connector in the top of the wand that connects...
(More)
I need to install part #PHP-236/C45ECUE. This is the connector in the top of the wand that connects the power to the brushes near the thumb switch at the end of the flexible hose. (Hope this makes sense....)
Thanks!
kenmore upright vacuum model 116.35923500. not rotating when on. Easy way to clean without taking...
(More)
kenmore upright vacuum model 116.35923500. not rotating when on. Easy way to clean without taking apart?
I had a bad connection between the Wire Harness on the handle and the Terminal Cover on the...
(More)
I had a bad connection between the Wire Harness on the handle and the Terminal Cover on the Extension Wand. I replaced the wire harness, the the vacuum runs great. However, I bought the terminal cover because one of the contact pins looks "rusty" and I don't want to cause another poor connection. Will you please provide instructions for the removal of the Terminal Cover? I've played around with this enough to know that I may start to break something if I apply pressure in the wrong places.
terminal cover - how to remove it so cord rewind can be replaced
