Question about Samsung Blackjack SGH-I607 Smartphone
Ring tone volume
I cannot find where I can adjust the ring volume on my blackjackII
  • skrappyfrass
    skrappyfrass Mar 07, 2008
    I just added a movie to my blackjack not realizing that the video would
    not occupy the whole screen. Now I know there has to be a hack for
    this. I have to squint to watch a movie. Please help I want the movie
    to occupy the whole screen.
  • mmsauceda Sep 09, 2008
    I can't adjust the ring volume either. It's stuck at a constant high level and I've tried several times to lower it. It's so loud sometimes that I just keep it on silent. Any suggestions??
    Problem Solver:
To turn up the ring volume on the blackjack, there are two on the left hand side above the ear/charger port a UP & DOWN. those i use to adjusted my volume.
Posted on Jan 22, 2008
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
What is the code to increase the volume of Samsung C3010
Hi
By volume do you mean Ring tone volume or Handset volume?
Ring tone volume adjustments.
Press menu >settings >phone profiles
Scroll the phone profile you ares using.
Press on options >edit and select call alert volume.
Scroll right or left to adjust the volume levels.
press on select and then save.
The handset volume adjust is done by pressing on the 1st side key in idle mode.
Feb 27, 2012 | Samsung Cell Phones
Can't find how to adjust message tone volume
Message tone and volume works together,so if you have your ring tone volume at the loudest level, the alert tone for messages will be at the loudest as well. If you want to adjust the volume follow these steps:
go to settings --> personal --> profiles --> choose any profile that you want to be activated on your phone --> options --> personalized --> ringing volume --> choose from volume 1 to 5 as the loudest --> press ok then click back once --> options --> activate
From there you are good to go.
Thanks for choosing www.fixya.com
Dec 09, 2011 | Nokia E63 Cell Phone
We have an older Uniden cordless telephone-Model #EXI7960 that seems to have a very soft ring tone. How can we increase the volume of the ring? Also, is there an owners manual on-line for download?
The EXI7960 has two ring tones and two volume settings available. With the handset in standby, press the Volume up button. (The volume up and down arrows let you switch both volume and ring tone. So you may have to press it a few times to adjust the volume.) The display should show the changes.
Retrevo has the manual here: http://www.retrevo.com/support/Uniden-EXI7960-Telephones-manual/id/471dj498/t/2/ . You will need to enter a code to access the PDF.
I hope this helps.
May 27, 2011 | Uniden EXI 7960 Cordless Phone (EXI7960)
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
A am not getting any sound when faxing or when faxes are coming through and my volume is on loud why is that.. I disconnected plugged it back in changed some settings and i still get nothing
Your HP all-in-one provides three levels for adjusting the ring and speaker volume. The ring volume is the volume of the phone rings. The speaker volume is the level of everything else, such as the dial tones, fax tones, and button press beeps. The default setting is Soft.
1 Press Setup.
2 Press 4, and then press 8.
This displays the Basic Fax Setup menu and then selects Ring and Beep Volume.
3 Press to select one of the options: Soft, Loud, or Off.
Note If you select Off, you will not hear a dial tone, fax tones, or incoming ring
tones.
4 Press OK.
Sep 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
How do I turn off the ringer volume??
I found this at hp website.
Adjust the volume
setting is Soft.
1 Press Setup.
2 Press 4, and then press 6.
tones.
4 Press OK.
Feb 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
RING TONE VOLUME TO LOW
While the set is ringing use the volume arrows next to the handset to adjust the volume.
Mar 26, 2009 | Samsung Prostar DCS-24B-LCD Corded Phone
Weak ring tone
Try going to the settings of the phone and adjust the Ringer Volume, sometimes you can do this by pressing the button on the side of your device, other times you have to go within the settings of the phone to adjust the volume.
Mar 18, 2009 | Lands Phones
Samsung Blackjack SGH-I607 Smartphone Logo
207 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
