Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Green light labeled timer flashes continually.
When I plug the tv in the green timer light flashes and the tv won't turn on.
SOURCE: Mitsubishi WS73713 - Now working - Timer light flashing.
The capacitors on the dm board are probably bad. I called mitsubishi and they agreed to pay for the part even though my tv is four years old. MITSUBISHI cust # is 1-800-332-2119
Posted on Jan 24, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Apr 03, 2009
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Posted on Jul 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: I plugged in the tv
Hi
Thanks for using FixYa. Continuous blinking green LED on Mitsubishi's Projection which normally blinks after a power surge means that the microprocessors inside the unit are unable to communicate with each other. Usually Mitsubishi's Projection TV use 1000uF/16 in the DM MODULE (which is one of the two microprocessors), as these capacitors are too small for the load they get they usually fail usually after about 3-5 years. They might also fail due to voltage fluctuations. To resolve this issue these capacitors should be replaced with 1000uF/25 volt or 1000uF/35 volt capacitors, so that they can handle any voltage spikes that will occur. To do the repair you'll need to take the back off the TV apart in order to remove the faulty DM module and need to desolder the old capacitors on DM board and install new ones. All this is only recommended to be done by someone who has electrical expertise. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 27, 2010
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
The green light labeled "Timer"
u have a bad control box to repair this unit is better to hire a tv tech , total cost may be $500
Nov 03, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
