Question about Cameras
BURN FOR INCORRECT POWER ADDOPTER - Cameras
Children taken away without any documents...
I saw what you wrote. I can't help you in that way, but I can pray Lord Jesus Christ for you that all finish good. All the best!
Dec 05, 2013 | Computers & Internet
I addopted a pet in a shelter but they never came by the house. Now I cant travel or move to another house. What can I do??
You could try posting in another CAT-a-gory. JK. You might find better answers.
This is for computer CPU's.
Oct 07, 2012 | Electronic Arts The Sims 3 with The Sims 3...
What does "incorrect disc" mean
It could be one of several things:
  • Dirty disc. Clean with outward strokes with a paper towel and water or Windex if needed
  • Dead DVD player
  • DVD may be for a region that your player does not support.
  • If the DVD is burned (home made), sometimes players are not forgiving and not all will play burned discs.
Feb 11, 2012 | Disney Princess TV/DVD Combo
My 98 exployer is misfiring on all 6 cycdeers but runs fine after warmed up
Misfires across all 6 cylinders could indicate the following:
Priority Action Part Type Cause 1 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 2 Inspect Distributor Cap Loose, Burned or Cracked Distributor Cap. 3 Inspect Distributor Cap and Rotor Kit Loose, Burned or Cracked Distributor Cap and Rotor. 6 Inspect Spark Plug Fouled, Damaged, Broken, or Incorrectly Gapped Spark Plug(s). 7 Inspect Coil - Ignition Faulty Ignition Coil. 8 Inspect Condenser-Ignition Faulty Condenser-Ignition. 9 Inspect Point Set Burned, Worn or Incorrectly Set Ignition Points. 15 Inspect Timing Specification Incorrect Ignition Timing. 19 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 21 Inspect Intake Manifold Gasket Leaking, Worn, or Damaged Intake Manifold Gasket. 22 Inspect Distributor Worn, Damaged or Faulty Distributor. 24 Inspect Valve Burned, Worn, or Sticking Exhaust Valves.
Nov 03, 2010 | 1998 Ford Explorer
Precision m60 power not staying on
hi first check addopter if power work fine then check ram if ok check proccessor if ok press main chip on board then check shortage may bee any fet or capceters shorts
Jul 18, 2010 | Dell Precision M60 Notebook
What could be causing a 2001 kawasaki kx 250 to continue burning spark plugs out?
incorrect jetting
incorrect ignition timing
incorrect plug heat range(could run a 9 or 10)
intake leaks
exhaust leaks
incorrect fuel oil mixture
overheating
is it burning the electrode off or carbon fouling the plug
sorry for the long list, there is probably a few you might discount as you have already checked
Apr 26, 2010 | 2003 kawasaki KX 250
Samsung 997DF 19 in.CRT ?
Those are signs that it shorted out or probably was lugged into an outlet with an incorrect power voltage,
You need to bring it to a service center to have the Power Supply (IC) replaced.
Thanks. =)
Dec 30, 2008 | Computers & Internet
Will not turn over
1 Inspect Battery Damaged or faulty battery and/or connections. grey_line.gif 2 Inspect Coil - Ignition Damaged or faulty ignition coil or ignition coil circuit. grey_line.gif 3 Inspect Fuel Filter Clogged or dirty fuel filter grey_line.gif 4 Inspect Fuel Injector Pressure Regulator Faulty fuel injector pressure regulator or circuit. grey_line.gif 5 Inspect Fuel Pump Improperly functioning fuel pump or circuits. grey_line.gif 6 Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). grey_line.gif 7 Inspect Control Module-Ignition Faulty ignition control module or circuit. grey_line.gif 8 Inspect Solenoid Switch Damaged or faulty solenoid switch or solenoid switch circuit. grey_line.gif 9 Inspect Starter Damaged, worn, defective, or faulty starter or starter related circuit. grey_line.gif 10 Inspect Neutral Safety Switch Damaged or faulty neutral safety swittch or circuit. grey_line.gif 11 Inspect Fuse Corroded, burned, or shorted fuse may be interupting power source. grey_line.gif 12 Inspect Fusible Link Corroded, burned, or shorted fusible link may be interupting power source. grey_line.gif 13 Inspect Battery Cable Corroded, broken or poorly connected battery cable. grey_line.gif 14 Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor. grey_line.gif 15 Inspect Distributor Cap Loose or cracked distributor cap grey_line.gif 16 Inspect Distributor Cap And Rotor Kit Loose, cracked, or worn distributor cap and ignition rotor. grey_line.gif 17 Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. grey_line.gif 18 Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector. grey_line.gif 19 Inspect Ignition Switch Worn, damaged or faulty ignition switch or circuit. grey_line.gif 20 Inspect Spark Plug Fouled, damaged or broken spark plug(s). grey_line.gif 21 Inspect Belt Incorrectly routed, adjusted(tensioned), missing or worn drive belt(s). grey_line.gif 22 Inspect Timing Belt Slipped or broken timing belt. grey_line.gif 23 Inspect Timing Set Slipped timing chain or worn timing gear(s). grey_line.gif 24 Inspect Fuel Tank Contaminated fuel from rusted or deteriorated fuel tank. grey_line.gif 25 Inspect Ignition Timing Incorrectly adjusted engine timing. grey_line.gifHERE is a list of thiung to check and ur car should fire right up Shaun
Aug 07, 2008 | 2000 Chevrolet Impala
Meade ETX-125EC Telescope Problem
Well, when I got the unit, indeed it would not power up at all. I could see no burning or signs of arcing.
I looked online for an internal picture of the drive and fitted the cables back in according to the image.
Tadahhhh, one working drive, only works on the 12v though, Batteries wont work although I have measured the voltage and they are all fully charged. Seems the previous owner had removed the looms and put them back incorrectly.
Mar 14, 2008 | Meade ETX-125EC (500 x 127mm) Telescope
Cameras Logo
13 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
