Question about Samsung SL202 Digital Camera
My lens comes out but will not open. what can i do to fix this?
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Lens protector stuck open
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. This article provides further information on correcting this problem.
Jan 24, 2012 | Canon PowerShot S90 Digital Camera
When I open the lens ti dosen't come out which
Please take it to a repairer, fixya does not fix anything for you, this website is advice only.
Feb 25, 2011 | Canon PowerShot SD1100 IS Digital Camera
My daughter dropped our A520. The power comes on for a second and then shuts down. The lens is stuck open. Is this worth fixing?
I had this problem once. The lens was stuck open and the power would not go on. I took out the storage card and the lens retracted.
Aug 23, 2010 | Canon PowerShot A520 Digital Camera
Sony HDR-XR200 lens cover problem
You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
DSC-WW220 CAMERA LENS IS NOT GETTING OPENED ,whenver i open lens comes out later it gets in and on screen it dispalys to do on and off
Its problem in lens.There is one part its called sensor it fix on lens it need to be clean.After cleaning your camera will work properly & there will no massage Turn the power off and on again
Feb 26, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
When using camera, the lens will not come completely open or clos
You have broken last (black) gear in opening/closing mechanism. Common problem. Need new gear or fix missing "tooth".
Sep 19, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens error, lens wont come out at all just started wasnt dropped hit or anything
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 27, 2009 | Sanyo Vpc-s1070w Digital Camera
Shutter over lens stuck open
If your lens comes out and retracs during power on or off then the spring that closes the lens is either broken or off trac. If you are out of warranty and able to open the case then it should be an easy fix. If not then you would have to get it repaired.
May 02, 2008 | Cameras
Lens cover will not full open up help needed
Mine wont open at all. You can hear the lens trying to push it's way out but the cover doesnt move.
Dec 27, 2007 | Olympus Stylus 800 / ? 800 Digital Camera
Open Questions:
See all Samsung SL202 Digital Camera Questions
Samsung SL202 Digital Camera Logo
62 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
