Question about Baume Et Mercier Capeland MOA08491 Wrist Watch
Stainless band too large. Need to shorten - Baume Et Mercier Capeland MOA08491 Wrist Watch
    Problem Solver:
  • 6 Answers
Take it to a jewler or watch mender cost £3 pounds to shorten i advese not to do it your self they have the tools to do it
Posted on Oct 03, 2009
Testimonial: "Thanks for the good advice. "
Band too large . How do I shorten an expansion band that does not have pins? It is the Timex Easy Reader
You din't. Take it to a jeweler and have them do it for you. If you've never removed links for an expansion band you'll destroy it in the process.
Jun 08, 2011 | Timex T26451 Classic Expansion Band Watch...
How do you shorten the wristwatch?
Thank you for contacting Fixya.<br /> <a href="http://www.webwatches.co.uk/how_to.htm">http://www.webwatches.co.uk/how_to.htm</a><br /> That link will dirct you to directions for different types of bands.<br /> Best regards. Jewel
Aug 26, 2010 | Armitron Blue Dial Stainless Steel Watch...
How does it get sized?
You can usually have your local watch shop to shorten watchbands but if they cannot do it then you could contact Michele watches.
You could then discuss any problem you have with them.
Insert "www.michele.com/" into your search engine, at the bottom of the page on the left is a "contact us" link. Click on this for info.
Feb 16, 2010 | Michele Watches 16mm Stainless Steel Watch...
Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Jan 04, 2009 | Tissot Le Locle Automatic Chrono Large...
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Stainless steel band won't snap into my watch
Stainless steel bracelet ends (so called wings) must be curved flush to the watch case.
Another way is to use curved spring lugs (pins).
Dec 12, 2008 | Philip Stein Teslar Large Gunmetal Watch
Need to shorten a band
you better pick one and size it according to your size, if not enough, pick one again to other side of the band in order to balance ,,until reach the size you want....
Jun 24, 2008 | gossip Watches
Invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
Baume Et Mercier Capeland MOA08491 Wrist Watch Logo
236 people viewed this question
Top Baume Et Mercier Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Baume Et Mercier Watch Expert? Answer questions, earn points and help others
