Question about HP Md5880n 58 in. HDTV
The t.v. has begun to sound like a fan i was told by an expert over the phone that it could possibly be the color wheel. what i would like to know is it worth fixing or just buy a new t.v. ? and how costly would it be to fix this piece?
  • 557 Answers
The noise you describe is a color wheel. Dont know the cost for your set or if its even avaliable since I cant find it listed. Most color wheels for that size set run several hundred dollars.
Posted on Oct 02, 2009
SAMSUNG HLN617W turns on, picture is perfect, then picture turns off after a couple minutes.. sound still works.. hear a noise that sounds like a fan starting up and shutting off. Picture will not turn on...
It's not the lamp, most of the time they suspected it and the fan gone to malfunction when encountered this kind of symptoms but the fault came from the color wheel. You have to replaced it to resolve the issue.
Oct 07, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Have a HLP 4663W... Picture fine but a loud whine upon start up that used to go away after about 5 minutes - but now is persistent. Someone had told me that the fan may have dust, but after doing some...
definately sounds like a color wheel, You can tell by listening to where the sound is coming from if its coming from the right side when looking in the rearabout six inches in from the left side in the middle of the light engine is where the color wheel and housing are located. the housing is held in with two screws and then unplug the 2 wire cables. You can get the replacement color wheel from www.tvrepairworld.com which has instructions.
Jul 19, 2011 | Samsung DLP HL-P4663W 46" Rear Projection...
Will not start when I press manual button then when I press the auto button, I hear a high pitched screeching sound. Is this a burner motor problem ? What is the fix? Thank You. Laser model 55...
fribue,
I am not an expert but I had a similar situation with my 55. My 55 was only making a droning sound when I turned it on. I contacted the company and they told me it could be excess carbon build up in the exhaust fan.
I accessed the exhaust fan from the back of the heater. I took a pencil with an eraser stuck it in the exhaust port and gently begun to spin the fan using the pencil eraser. After a minute or so the exhaust fan starting moving very freely. Then it worked like a charm
I hope this helps.
Oct 25, 2010 | Rinnai Toyostove Direct Vent Heater:...
I own a toshiba 62hmx85 tv and had a frequent humming sound coming from the tv, technicians told me over the phone that it could be the color wheel going, soon after that the tv stopped working and all i...
The color wheel on this set is not available. First thing I would do is replace the lamp. MCM electronics has a Philips for $99.00. The hum could have been the lamp fan which is common on these sets. There is a kit from Hitachi the includes some rubber dampers. What I commonly see on these sets is when the lighr engine is going bad(this is where the color wheel is) the color gets a green,bue or yellow tint and trhe picture may get dim. its rare that the color wheel stops working on this model. Call adifferent tech for sevice. Anyone with experience on these sets will know whats up.
Dec 03, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Model 5063W - loud noise
The picture is pink, that would point more toward the color wheel, and you can see the fan through the vents in the back and you can go from there. It sounds more like the color wheel since you have a picture malfunction.
Jun 24, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
HLN5065W picture turns black and white and shuts down
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. This is a known issue in this TV! Expect to spend $300-500 to have this serviced by a service company. If you have the right stuff, you can do it yourself. If you search the web, you'll find a color wheel for this TV for under $100, but installation can be tricky.
michtech
Feb 16, 2009 | Samsung HLN5065W 50" Rear Projection...
Can you help me with my TV problem???
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. Your TV may have a new type color wheel assy that has a slightly different configuration but the result is the same.
michtech
Oct 12, 2008 | Mitsubishi WD-73732 73" Television
Color fades out on tv
I have the same tv and the same problem (color banding, incorrect colors, colors blinking) occured after I replaced the lamp. I had a tv repairman take a look at my unit and he said the color index was incorrect, the tv doesn't know the correct colors to display. The best way to fix that problem is to replace the "light engine". The repairman replaced the "light engine" to my tv and everything is working great. My tv was still until warrenty so I don't know how much a new "light engine" would have cost.
Jul 27, 2008 | Mitsubishi WD-73732 73" Television
HP Md5880n 58 in. HDTV Logo
225 people viewed this question
Top HP Televison & Video Experts
Tony
Computer Links
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
