Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Fridge not colling, freezer is
Fridge not coolling, freezer is working great
    President:
  • 744 Answers
Hi, With the information you supplied i\'m going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don\'t worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike
Posted on Oct 01, 2009
Testimonial: "Awesome advise. Thank you."
My freezer is coolling but my my fridge isn't
Check the airflow, to the fridge, if it is stopped up, check the fan, if OK, check the defrost timer.
Jul 25, 2015 | Refrigerators
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
installed.
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
Westing house frost free bottom coolling then eventually stop freezer alright
If the fridge still working check the fan for the freezer
Mar 21, 2013 | Refrigerators
Fridge not cooling
The evaporator fan needs replaced they are fairly inexpensive.
Sep 04, 2009 | LG LRTP0931 Top Freezer Refrigerator
Freezer works, fridge does not,runs constant though
Try turning it off and defrost it for 48hrs with both doors open. Then turn it back on if it's still not colling the fridge then you need to check to see if the fan in the freezer goes at all. If it cools for a few days then goes warm again you may need a new D'frost element, D'stat or something else cheers
May 15, 2009 | Electrolux Refrigerators
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fridge is warm, freezer works.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Smilar problem, but the model is GTH15BBMFLWW
Jul 16, 2008 | GE (GTS16BCS) Top Freezer Refrigerator
My american fridge don't appear to be cooling properly and some black stuff keeps appearing in the fridge compartment. it also keeps making rattling noise now and then!! Can you help?
my advice is check and replace the fan in the freezer or the fan blade remove the back cover where the fan is in the freezer the freezer does all the colling for the unit
May 09, 2008 | Refrigerators
Kenmore 5355
There is a fan inside the freezer which circulates cold air through the air diffuser and then through the return duct at the bottom of the fridge. This fan may not be working. You should be able to hear it when you open the freezer door. If you cannot hear the fan going with the door open, keep the door open and press the button that switches the internal light off. The fan should run. If no fan running in freezer test for supply to fan. The fan may be faulty or the thermostat which is in line with the fan could be faulty.
Oct 29, 2007 | Kenmore 50522 / 50524 Side by Side...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
80 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
