Question about Toshiba Computers & Internet
How to remove toshiba satellite a135-4407 keyboard
How to remove toshiba a135-4407 keyboard
    Scholar:
  • 67 Answers
3 keys on my keyboard do not functon
Toshiba Keyboard Replacement - Satellite Laptop - YouTube
? 5:19
www.youtube.com/watch?v=F62RbnA06Fo
Mar 6, 2012 - Uploaded by Jennies Garage How to remove and install a keyboard on a Toshiba Satellite laptop computer. The tutorial is performed on a .
Oct 16, 2015 | Toshiba Satellite Computers & Internet
How to replace keyboard on Toshiba satellite c55t-b5230 laptop
? 5:19
Mar 6, 2012 - Uploaded by Jennies Garage How to remove and install a keyboard on a Toshiba Satellitelaptop computer. ... This video should help If I ever think ofreplacing the keyboard.
Sep 17, 2015 | Computers & Internet
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
I have a toshiba satellite 2415_s205 and cannot get the top off to repair power supply connector on the motherboard. It's being held by one point near the center of the keyboard and have removed all...
Sounds like you need the Service Manual for the Toshiba Satellite 2400 Series.
Here is one for the Satellite 2405,
http://tim.id.au/laptops/toshiba/satellite%202400%202405.pdf
This is a PDF file download. Should you not be able to download it, come back and state so, and I will give you the link it came from.
Under the keyboard, (Keyboard removed), there is a metal Support Plate. Remove the 4 screws that attach the Support Plate, and the screw you seek is right there.
(S03)
If you need further information let me know.
Nov 09, 2009 | Toshiba Satellite 2415-S205 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Satalite m35x-s161 how to replace the keyboard?
Toshiba Satellite How to remove keyboard and upgrade memory modules. This post was written by cj2600 on April 28, 2006
Posted Under: Toshiba Satellite A20/A25 --> toshiba-satellite-a20-a25-memory.jpgRemoving and replacing memory on a Toshiba Satellite A20 or A25 notebook is not as easy ad it should be. Both memory modules are located under the keyboard. A laptop keyboard has to be replaced in order to get access to the memory modules. Before you remove the keyboard do not forget to remove the laptop battery or you can damage the laptop. Be careful when you remove the keyboard securing strip; do not bend it too much. To remove the memory module from the slot on the system board, release the latches on both sides and the memory module will pop up. It will stay at a 30 degree angle to the system board. Firmly grasp the memory module and remove it from the slot.
Oct 31, 2009 | Toshiba Satellite M35X-S161 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
207 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
