I need to know the identity of a part installed on the power supply circuit board marked "TNR1". It is located next to the fuse very close to the power switch. It has two leads to the circuit board, appears to be covered by heat-shrink tubing and is semi-circular across the top. This part and the fuse (located next to it) were damaged in a power surge and replacement of TNR1 would appear to put me back to work. Thanks.
When I print or copy there is a 1/2 inch blank strip on the left side of the printed page. I tried...
(More)
When I print or copy there is a 1/2 inch blank strip on the left side of the printed page. I tried putting a new cartridge in the 1600 but the same problem occured. Is this fixable?
My Dell 1600N does not print dark enough. I have done all the adjustments available and still the...
(More)
My Dell 1600N does not print dark enough. I have done all the adjustments available and still the same.
paper coming out of printer stops half way out. I must open the door to the toner cartridge and...
(More)
paper coming out of printer stops half way out. I must open the door to the toner cartridge and close it for the paper to continue.
I keep getting and error message of "non-dell cartridge" and won't let me do anything. It...
(More)
I keep getting and error message of "non-dell cartridge" and won't let me do anything. It is a generic toner cartridge but is there away around this?
i have the dell 1600n working on a network, has been working approx. 2 yrs and has now just stopped....
(More)
i have the dell 1600n working on a network, has been working approx. 2 yrs and has now just stopped. None of the CPU's can print to it, but it will scan to the CPU's. Any ideas for my problem?
