Question about Maytag Atlantis MAV6000 Top Load Washer
Slow spin cycle, clothes still very damp
My Maytag MAV6000AWW started leaving clothes very damp after they were done. Wife said it seemed like the spin cycle was slow. I checked and yes it is slow, and when I manually stop the cycle, the drum stops suddenly and makes a slight screech.
Are the bearings going bad, transmission locked between gears, or what.
I pulled the front off the machine and ran it through a spin, then shut it off. Small amount of water seen in the pump housing, but nothing blocking the hoses, so I feel it's NOT a problem with the pump or belt.
Please help.
    President:
  • 1,304 Answers
Ahhhh but it is
needs a new belt
it is strectched
Posted on Oct 05, 2009
Maytag MAV6000AWW washer will not run thru cycles consistently
yes it would be the timer but they also stop if it gets off balance if its just off balance u should be able to lift the lid rearrange then start it again if that doesnt work it is the timer
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Asko w6021 washer leaves clothes damp and often stops mid cycle
I AM NOT MUCH OF A MECHANIC, BUT I DO KNOW THAT IF WATER DOESN'T SPIN OUT OF THE WASHER, IT COULD BE THAT YOUR BELT IS BROKEN OR YOU NEED TO REPLACE THE MOTOR COUPLING.
May 13, 2009 | Asko W6021 Front Load Washer
Wet clothes after spin cycle
When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 05, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Our Maytag Neptune MAH3000 does not advance through the rinse and spin cycles. The problem is sporadic. Sometimes it advances through one or two spin cycles and then stops, sometimes it stops on the first...
Have you cleaned the large drive belt, if it slips it could cause this sort of fault. Motor will stop if it doesn't get a signal from the drum. Just try wiping the drive belt with a damp soapy cloth and then wiping again with a damp non soapy cloth. You will need to remove the back, unplug it from the power before starting any work.
Apr 30, 2017 | Maytag Washing Machines
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Jan 12, 2009 | Maytag Neptune Washer
Clothes still damp to wet after spin cycle
You need to clean out your outlet filter; this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. And rate me pl, if the solution has worked......
Dec 02, 2007 | Washing Machines
Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Jun 12, 2007 | Maytag Performa PAV2200
Maytag Atlantis MAV6000 Top Load Washer Logo
507 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
