Question about Mtd Garden
I have a 4 year old MTD Yardmachine 13.5 hp,38'' mower deck.Mdl. # 13AC762F516 060-1813-6. Ser. #1B155B40302 000001.Recently it started jumping in and out of gear with a jerking motion.It did not do this all the time so I kept using it, but very quickly it got worse and I parked it.This is not a hydro-static driven machine but rather belt driven. I have tried adjusting the speed control linkage and the F-N-R linkage and it seems to change the operation but I can NOT get it to engage and run smoothly as it should. Is there something wrong with the transmission? Please advise. Len Trach 204-667-7010
  • 472 Answers
THATS WHAT IT SOUNDS LIKE
Posted on Oct 02, 2009
Mtd yardmachine 7 speed shift to go is my mower. it runs but want pull. does it have 2 belts or just the deck belt. the deck belt has more play than normal ..i think. as i was cutting the grass it stopped...
There are two belts, one for the deck and one for the main drive. The main drive belt can be seen on the upper pulley under the engine. Check to see if it has slipped or broken.
Aug 02, 2011 | Mtd Garden
Mtd snowblower yardmachine 3 hp/21"
if you are standing at the handles of the snow blower , kneel down there should be a sticker on the drive cover between the wheels , hope that helps
Jan 13, 2011 | Mtd Garden
I have a MTD rider, iam looking for a cheaper deck...
Try your local NAPA store. Bring the old belt with you.
May 21, 2010 | Garden
Wont start and lost manual for a mtd yardmachine 8/26
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets...but most of the time you will need to rebuild the carburetor. If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank. When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Dec 24, 2009 | Mtd 22" White Outdoor Self Propelled High...
I have a 1999 Yardmachine(MTD) model #13AS679G062, serial #1H287H2007-42 inch deck; when cold starting, the blades do not disengage, with the lift deck all the way up, clutch pedal depressed. I have...
Yes worn belts do stretch. On an MTD mower, like yours, there are blade brakes assemblies on either side of the mower where your feet rest. They stop the blade rotation when they make contact with the top of the deck pulley assembly. Part # 761-0168B Is the part # , you are looking for, you will need two of them.
Good Day.
Oct 09, 2009 | Garden
Riding mower won't start
Check the starter. Sound like the gear on the starter is stuck or broken off and not engaging flywheel.. Just your starter is spinning
Jun 16, 2009 | Mtd Garden
42" mtd yardmachine belt keeps coming off
twords the rear of the deck there are two bars with pins that hold the deck.they should have 3 or 4 holes where you can adjust the rear of the deck.check to see if there set to the middle somewhere,if so you can disconnect the 2 pins and try going up 1 hole iif that didn't work try down 1 from original point.
Jun 03, 2009 | Mtd Garden
Installing lawn mower battery
I have Yardman, MTD, 13 HP, 38", 6 speed. Put in new spark plug and new battery. Started first time and successive times (2), battery is completely drained. Can be jumped and started and will mow, but when it is shut off, there isn't any battery to restart. What would be draining the battery or not allowing it to recharge????
Sep 09, 2008 | Garden
Garden Logo
655 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
