Question about Brother GX-6750 Typewriter
CARRIER WON'T RETURN BACK TO THE CENTER
WHEN YOU TURN THE TYPEWRITER ON IT MAKES A GRINDING NOISE.
RIGHT NOW IT IS ALL THE WAY TO THE LEFT HAND SIDE AND IT WILL NOT MOVE.
FIXED IT ONCE AND THEN WHEN WE HIT ENTER IT SLAMMED ALL THE WAY TO THE LEFT AND GETS STUCK. ANY IDEAS?
    Master:
  • 619 Answers
Make it sure the cover of typewriter was lock ,self lock no movement of cover means good operation of typewriter.
Posted on Dec 30, 2007
How do I fix my Smith Corona SC110 Typewriter?
make sure the right hand platen knob is tight hold the platen and turn the knob top toward the back of the typewriter until it is tight
Aug 17, 2014 | Smith Corona Wordsmith 100 Typewriter
Olympia Startype electric typewriter , make a funny noise and won't move carriage. Can not get it to work.
Turn it off and see if the carrier will move back and forth by hand if it will but feels a little gummy spray a little WD40 on the silver shafts that it slides on. If it won't move by hand look for debris in the carrier area.
DickyO
Sep 19, 2011 | Olympia Office Equipment & Supplies
Print head moves left and stays horrible noise
The problem is either something is interfering with the carrier movement OR the carrier homing sensor is broken/defective. First, turn off the power and manually move the carrier to the right side frame, check for foreign objects in the machine (pens, pushpins, paper clips etc.). Put some oil (10 weight) on a cloth and clean the chrome shaft that the carrier travels on.(by the rubber cogged belt). This is a common problem. If the sensor itself is the problem, take to a repair shop.(not common)
Nov 24, 2009 | IBM Wheelwriter 30 Typewriter
Carrier stays to the left
Look inside the machine and make sure nothing has fallen into it that may be blocking the carriage from reaching it's "home" position. Sometimes a lift off spool will fall off and do that.
Apr 16, 2009 | Brother GX-6750 Typewriter
Ribbon replace on ibm selectra 2
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Feb 08, 2009 | IBM Wheelwriter 30 Typewriter
New typewriter
On the right side of the typewriter, just beneath the carriage (as you are facing the typewriter) there is a small metal lever which you need to push back. It is the carriage lock used to hold the carriage in place when it's being transported in the case.
May 17, 2008 | Olivetti MS25 Typewriter
Carriage return
Try a slightly oily cloth and wipe the bar that the carrier moves on several times then with the machine turned off try to move the carrier both left and right to each end it should have some resistance but not be hanging up, you may have to do this several times. Good luck
Feb 07, 2008 | Lexmark Wheelwriter 1000 Typewriter
Typewriter won't return carriage
try wiping the large bar that runs left to right under the carrier with a cloth wet with a light oil and then move the carrier by hand to see if it will free up. Be sure the typewriter is turned off.
Oct 01, 2007 | IBM Wheelwriter 30 Typewriter
Brother GX-6750 Typewriter Logo
143 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
