Question about KitchenAid KEBC107 Electric Single Oven
Timer buzzer is stuck on and the timer is stuck on 43 seconds. I tried cutting off the power but it won'tstop. Any ideas? Kitchenaid Oven KEBS107
3 Suggested Answers
SOURCE: whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Posted on Feb 03, 2008
  • 1314 Answers
SOURCE: Displaying DOOR
there is two fuses a 15 amp and a 20 amp fuse on the left hand side of the microwave one or both have blown
Posted on Jul 08, 2008
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
I replaced the flash timer on my oven and the power still does not come on what else could it be???
Is the electronic timer in the manual mode?
Is the element faulty?
Poor connection at the oven element terminals?
No voltage output from the oven thermostat control?
The oven thermal cut-out switch has operated and cut all power to oven?
Feb 08, 2011 | Frigidaire Ovens
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
Feb 02, 2010 | Belling XOU592 / XOU593 Electric Double...
New world DFEO 70, fan oven not working but top oven is? Why? No power at all on fan oven & no time showing (not lit up)
oven timer seems to be stuck - oven only comes on for about min. and then cuts out to 'pinging'
how do we reset the timer to 000 ?
please
Jan 23, 2010 | New World Ovens
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Whirlpool super capacity 465 timer won't beep
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
E1 and f5 error/Door locked
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
GE digital Timer Oven
most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
Nov 22, 2007 | GE JKP27 Electric Double Oven
KitchenAid KEBC107 Electric Single Oven Logo
66 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
