Question about Compaq Computers & Internet
I have acompaq presario 6000 but when I moved and plugged my speakers bak in al I get is static. I cannot get any sound. I plugged the speakers into another computer and they work just fine so the speakers are not the [roblem
  • 380 Answers
Make sure you are plugged into the small green 3.5mm jack. if there is no sound whatsoever, then it is a failed amplifier. if there is staticky sound then you likely have a failed 3.5mm jack. Try plugging the speakers into a headphone port (if available) or disable to on-board sound device, puchase an add-in 3d soundcard and circumvent the issue.
Posted on Oct 01, 2009
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Sound is distorted and echo's
check the speaker plug/outlets is usually if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is or a can of compressed air
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jul 29, 2012 | Compaq Presario CQ57-410US 15.6-Inch 320GB...
Charging
Does the DC charger come in two parts ??
If so check both parts, if you do not get a light on converter(square box) and did before it is converter...
May 17, 2012 | HP Compaq Presario C304NR Notebook
Altec-Lansing VS-2120 speakers problem: Right speaker gives no sound, although computer checks out on other speakers, and headphone plugged into this speaker set works on both channels. Also get static...
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Aug 30, 2011 | Computers & Internet
My woofer and speaker make a lot of static and one speaker does't have any sound, it seems that when I move the blue connection the one from the speaker to the woofer the woofer gets louder and so does...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 29, 2011 | Boston Acoustics BA745 Computer Speakers
Why is my left speaker coming out with no sound, but my right speaker (no controls on it) is working? To note, when I move the cord that plugs into the sound source, I hear crackling in the left speaker...
is the cord you move laying on a rug or carpet this will cause static
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 23, 2011 | Juster AC-691 Computer Speakers
Buzzing static sound in speaker
Static can be caused by a few things.
Does the static persist if you unplug the audio cable from your computer?
If so, the static is being caused by the amplifier built in to your speakers.
If not, the static is probably caused by interference on your sound card. Try plugging the speakers in to a portable media player. You might need to replace the sound card in your computer.
May 13, 2010 | Bose Companion 3 Series II Multimedia...
I have acompaq presario c700 laptop, and having problem in finding the drivers for bluetooth,modem+driver and webcom for+compaq+presario+c700
If u r using Vista,Type devmgmt.msc in the search box and press enter u will see al drivers there.
If u r using XP,Click on Run and Type devmgmt.msc
Jul 04, 2009 | Computers & Internet
Static coming from my DELL AS500 speakers
It's the jack on the back of the PC or sound card. Sounds like some solder is loose on the jack.
The cheapest solution would likely be to just replace the sound card, if your comfortable installing them. It's really quick and pretty hard to mess up.
If it's "onboard" sound, meaning the audio jacks are built right into the mother board, you'd likely need to just replace it with a pci based sound card.
Dec 06, 2008 | Dell AS500 Sound Bar Computer Speakers
Half a Screen
Check first by connecting it to an external monitor. If you see that it is the same problem in the external monitor then I think there is something wrong with your video card. See if you can re seat the video card.
This issues also come from the cable that connects the LCD with the motherboard. Have you opened the Laptop anytime and moved the cable?
Check these first. It sounds something loose or a something related to video card.
Jan 16, 2008 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
