Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Will not start. Nothing happens when the key is turned.
New Battery installed. checked seat switch & is OK.
  • 1,165 Answers
Are you getting spark and or gas .i bet you check your fly wheel key itll fix it..they are known to partially shear ,giving you spark and gas but will not run.because when the key is sheared it throws the timing off.
Posted on Oct 04, 2009
Craftman 18 hp won't start with key
Check Battery. If headlight equipped turn key to headlight on position and see if headlights are lit. No light dead battery dead tractor,
Charge battery. If after charging weak or no start forget the battery and get new, Life of battery is two to three years,
If battery good make sure that parking brake set and blades are not engaged. Safety lockout will prevent tractor from cranking. The tracker has a safety interlock on the seat that requires a body warm or cold sitting on the seat if the parking brake is not set. The seat switch is known to fail. Try bouncing on the seat?
OK if battery OK and seat is sat or park brake set we can assume the safety interlock circuit is disabling the start circuit.
Need model to provide more answers
This website video shows how to check the component. Your model would be similar.
How to test lawn mower electrical safety switches
This electrical diagram is for a typical lawn tractor. Your model would be similar but different . This will give you an idea. The switch on the seat has two sets of contacts.26045611-oxnapdkevdwqbvzn03d44ye1-1-0.png
Jan 09, 2016 | Garden
Keys turns on but wont start the engine
check:
battery good 11 v min
battery conecctions cables, all clean
if automatic trans, in park or neutral selector
if standar trans, press the clutch pedal full down, check switch in pedal
the dash lights all on in switch on, check for antiefth extra
alarm disabled
and doors closed, seat belts
or crank start but engine no start need a full diagnosis for qualificated personal.
Sep 09, 2014 | Cars & Trucks
Husqvarna yth1848xp wont turn over
Are you getting 12 volts to the starter? It sounds like one of the safety switches (seat switch) may be killing the circuit. The seat switch cannot simply be jumped. And check the 20 amp fuse.
May 30, 2014 | Husqvarna Garden
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
Won't start
How about corroded battery cables (internal)
Fusible Link wiring corroded & open circuit,does
everything electrical work except the starting circuit?
Turn key & have power to starter solenoid ?
Neutral Switch !
Ignition Switch !
Tough to guess without wiring diagrams,
to see where to start testing
Can't fix what you don't know you have
Oct 02, 2012 | 1990 Ford F150
19.5 hp twin craftsman serial number 917259560 turn key nothing happens battery new, switch uner seat in ok position
Check that the blades are not engaged. If they are not engaged and you still have nothing, check battery cables tight. Then check the starting solinoid.
If you have any questions on how to do this or other related, just reply.
Jul 13, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears Craftman LT2000 does not start
bad safety switch one under seat ,clutch pedal,blade engage leaver
Sep 01, 2009 | Garden
I have a 1997 Grand Am 2.4 SE that won't start
Check battery full charge, battery terminals are clean, cables aren't cracked, broken or corroded and alternator first.
Which your having replaced your starter with new already. If you're still getting nothing it sounds like a bad ignition switch.
They wear normally and need to be replaced. But as a helpful hint don't place excess keys or weighty trinkets on your ignition keys.
They wear on the seating of the key in the ignition and often promote failure in the ignition from bearing the dangling weight.
Jul 27, 2009 | 1997 Pontiac Grand Am
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
326 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
