Question about GE Refrigerators
2 circuit boards burned up
Freezer fan motor and now water ice not working. I removed and tested fan plug for power but there was none. repair tech said board was bad so I bought a new one and installed it. Fan did not start working but water and ice did. Within an hour same resistor burned up. What's melting the resistor ?
  • ssgtpitt Oct 01, 2009
    Thanks Joe, the fridge is 6 years old. I hate to buy a new fridge every 6 years. I can purchase and install the motor myself. The circuit board was less than $100. Is there a way to replace the resistors on the board ?
    I'll purchase the new parts and see what happens. THanks for the help.
  • 10,865 Answers
The fan motor is shot. You need to get an estimate on a repair and compare that to the savings over time of purchasing a new, efficient model. good luck with it.
Posted on Oct 01, 2009
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
Ice Maker doesn't work, condenser fan was not running
It could be the the control board or a broken wire in the door.
But if you hear the timer motor running then you are getting power to the ice maker.
Have you check the temperature in the freezer?
The freezer must be 5 degrees or below for the ice maker to work.
Here is a link on how to test the ice maker.
Jul 20, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
What does LF flashing red mean
Noise coming from center back of refrigerator sounded like fan scraping on something. Repair person replaced fan and supposedly a green circuit board. Now there is frozen water under the drawer on the...
Fire these guys immediately. If someone did go behind they could cut off the water supply to trick you. Too bad I can't visit, dishonest techs disgust me.
Oct 29, 2013 | Refrigerators
My GE Side by Side refrigerator stopped making ice and dispensing water.
Check out the solenoids and power to the water solenoids for ice maker and door water.
Aug 22, 2017 | Refrigerators
After a power outage the ice make didn't work. We defrosted and cleaned out all of the ice in the freezer and it still didn't work. Now there is water leaking out of the freezer and the fridge is...
The E/F error code is indicating a problem with the evaporator fan motor inside the freezer. It could be caused by a failed fan motor, control board or a loose wiring connection between the two components. The control board monitors the evaporator fan motor operation and speed. If the control board does not receive information from the fan motor or receives incorrect information because the fan motor has stalled out or is not running correctly "E/F" will display. This type of error code will require a service technician in order to diagnose the failure. I recommend calling a service technician to repair your refrigerator.
Sep 24, 2011 | Refrigerators
COMBINATION OF PROBLEMS WITH MODEL 25 HOT POINT SIDE BY SIDE. UNPLUGGED IN FREEZER FAN SO REFRIDEGERATION UNIT WORKS AND TOOK OUT ICE/WATER CHUTE LIGHT SO WATER INDOOR DISPENSER WORKS. LOOKED AT CIRCUIT...
i think you answered your problem / sounds like the board. some times you can smell the burn and some boards have clicking sound . / from what you have stated . i would replace board. mm the burn is the price of the board .. mm
Dec 03, 2009 | Dryers
Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Aug 09, 2009 | GE Refrigerators
Ice maker won't work
If you are sure that power is getting to the ice maker unit inside the freezer and you're sure that water is available for the ice maker...
Try these next steps:
Follow the water line for the ice maker back to the ice maker water solenoid
Follow the wiring from the water valve to its source - either a timer or circuit board
Check the timer and/or circuit board for any bad connections, burned connections and power to the board or timer. This arrangement can vary by refrigerator model number...
Apr 11, 2009 | Refrigerators
Refrigerators Logo
23 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
