Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer is leaking, but I dont know why
The washer washes and everything, but its starts leaking when the washer is getting filled at the begining of the cycle or whenever water is use. it leaks from the bottom towardthe front of the machine
    President:
  • 744 Answers
Hello, the most likely cause is the pump. Whirlpools are direct drive machines which means they do not have a beltwasher is leaking, but I dont know why - 2.gif. The pump is hooked up directly to the motor. To confirm this is the pump tip the machine back so that you can access it underneath. Make sure you wedge something underneath so it does not fall on you. Next take a look where the pump joins onto the motor shaft, this is where you will find the leak. This pump is a sealed unit so you will have to replace the whole pump. You can do this by removing the inlet and outlet pipes. Next with a screwdriver release the 2 clips holding the pump and remove the pump.....reassemble with new pump in reverse order. Good Luck!! If you have any further question's please feel free to comment. Mike
Posted on Oct 01, 2009
Washer wouldn't stop filling and leaks
Hello, here is a great link to check out everything you can think of on your washer repair and trouble shooting. Make sure you really check out the different areas to click on on this site..
Here is the link. I hope this helps you, mike
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Oct 20, 2011 | Whirlpool LCR5232H Top Load Washer
Washer does not fill with water and starts agitating when turned on
Check around the motor, it sound as if you may have pulled a wire loose somewhere.
Jul 08, 2008 | KitchenAid KAWS850L Top Load Washer
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Washer is draining as it's filling -up. Checked all hose there on and no leaks coming from them. Could it be the plastic pump?
This could be a simple matter of drain hose placement. What it sounds like you are experiencing is known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Double check your drain hose placement and the size/height of the standpipe. If you don't have a sufficient air gap, your washer will begin to siphon water from the tub as it fills. The drain pump cannot cause this problem on the fill cycle as it is driven by the drive motor. The drive motor will not engage until the washer is filled and the wash cycle starts.
If you have questions, please let me know. I hope this is helpful.
Aug 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
While i'm washing water is getting on my floor, I don't know if it is when spinning or washing what could be the problem?
Help me help you...Dry the floor...Set the load size to small. Let it fill and start the wash cycle. Stop the unit. Look underneath it. Is there water on the floor? If so let me know. If not, start it up again and let it complete the wash cycle. As it begins to drain, look for water on the floor. Let me know.
I am trying to help you eliminate (or isolate) a bad tub seal, centrifigual force out, or a drain pump issue. When the water actually begins to leak is the key element we need to know in order to solve your problem. :) 2CR
Jul 31, 2009 | GE WJSR4160DWW Top Load Washer
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
131 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
