Question about Frigidaire Ovens
Stove burners don't get hot enough and the oven takes a long time to preheat
  • 736 Answers
Sounds like its wired incorrectly .. the stove operates on two phases of 120 volts each .. together they form a 240 volt supply .. if its wired incorrectly you may be getting only 120 volts .. it will then take 4 times as long to heat .. have an electrician or someone skilled in that sort of thing, check the voltage at the plug .. and make sure the pig tail is attached correctly to the stove .. check the circuit breakers .. there is one for each phase .. but if one is tripped then some functions wont work at all unless there is a second problem (shorted phase) in which case it will work but have the 4 times as long to heat problem and it will trip the circuit breaker immediatly .. ..
Posted on Oct 01, 2009
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Upper oven takes forever to preheat
    Deborah...all stoves have a row of fuses, usually under a strip cover. It sounds like one of the burner fuses have blown and needs replacing.If one is blown you would only have 110 volts on the element instead of 220 volts which would make the element only half as hot.
    Dec 20, 2014 | Fisher and Paykel AeroTech Double OD302...
    Gas oven takes 30 mins or more to to preheat
    Open the bottom and have a look at the burner while its heating. The flame should be strong blue/white and both sides the same, if they are not you have some blocked holes in the burner. Remove the burner and clean out the holes (carefully, don\'t ream them out, use a small paperclip to clean them, be gentle.). Above all do NOT use any kind of oven cleaner on them, if they are aluminum, and most are the oven cleaner will destry it.
    Jul 29, 2014 | Kenmore Ovens
    Oven takes long time to preheat
    if the oven has a glow bar it,s not staying hot enough to keep the main burner on change the glow bar
    Nov 23, 2013 | Whirlpool SB160PEE Gas Single Oven
    Frigidaire gallery stove, oven not working,
    Morison,
    The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
    May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven appears to start, takes forever to preheat,
    This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
    Feb 26, 2010 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Slow and uneven ignition on the oven burners that causes the oven to take hours to preheat
    MOST OF THE TIME THIS IS CAUSED BY A WEAK IGNITOR.WHEN THE IGNITOR IS WEAK IT WONT PULL ENOUGH CURRENT THROUGH THE GAS VALVE TO OPEN IT UP.SOMETIMES IT WILL OPEN ONLY PARTWAY .GOOD LUCK!
    ERIC
    Jan 23, 2010 | Viking Ovens
    KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
    Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
    Apr 25, 2009 | Ovens
    Oven not working properly
    I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
    Nov 29, 2008 | GE JGRP20 Gas Single Oven
    Oven slow to heat and top burners weak flame
    sounds like you have a gas pressure /flow problem. id start with hte gas company have them come out and check you tank pressure(if using LP), or the pressure from reguator leading to home
    Mar 13, 2008 | Ovens
    Ovens Logo
    136 people viewed this question
    Top Frigidaire Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Sal DeAngelo
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
