Question about Forfex FX 652 Hair Trimmer
Power adapter for forfex fx652
I can't find a supplier for a replacement power adapter??????? Pretty frustrating
  • hdesignert Aug 09, 2008
    i need to find a replacement cord, and or charge base. Anyone have any luck?
  • Anonymous Sep 03, 2008
    I cant find a power supply. Has anyone been able to find it
  • 4 Answers
There are very few parts available for Forfex products, are you sure it is the power adapter? If the clipper is 3 years or older most likely it is the battery inside the clipper, check their website for service centers.
Posted on Feb 04, 2008
I got this laptop to check it because it does not turn on. I have checked the AC adapter and it gives 19 volts for only two seconds and then it goes stable to 1 volt. Could it be the ac adapter?
Yes. The power supply should provide 19 volts continuously when plugged in. You can get replacement ac adapters pretty inexpensively on eBay. Make sure that the wattage (and/or "mA" rating) of the new adapter is equal to or greater than the current one.
Also be sure that the connector is the right size for your laptop. Most suppliers have a compatibility checker on their webstore to make sure that the connectors are compatible.
Aug 30, 2015 | Lenovo ThinkPad T410 Notebook
I NEED A REPLACEMENT AC ADAPTER FOR MY VENTURA 7'' DVD PLAYER MODEL PVS12706E,
I recommend you contact your supplier manufacturer, and order the AC adapter.
God bless you
Aug 06, 2012 | Televison & Video
Need to order a replacement battery and manual for Forfex model FX766
Here is the phone # to manufacture of your Forfex trimmer 800.326.6247
Mannys-sharpening.com
May 08, 2011 | Forfex FX766
The power light is off The charger is OK with 19Volt The connector is OK and somehow there is a problem with in the power
remove the battery, connect the ac adapter and turn on the laptop. If it turns on then it's your battery. If it doesn't turn on then it is either your ac adapter, your dc jack, or your system board.
If it doesn't turn on then try a different ac adapter from your local pc shop or electronics store. If it still doesn't work then try moving the ac adapter connector and see if it attempts to turn on. If it does then it's your dc jack. If it is your dc jack then you will have to replace it. The problem with that is that it can be pretty expensive to replace it.
The way I have solved this is by ordering a dc jack on ebay or any other online parts supplier and replacing it myself. If you can take your computer apart and put it back together then it's just a matter of desoldering and soldering the new one. If you want you can have a pc or tv shop do the soldering for you.
Have fun and let me know if you have anymore questions.
Dec 14, 2010 | IBM ThinkPad X60 Tablet PC
I am look for a charger for forfex babyliss pro model fx652 3.6v dc 1a
I have a charger for a forfex clipper fx 652, if you contact me sweenytodd@operamail.com I can give you details...
Sep 14, 2010 | Forfex FX 652 Hair Trimmer
I need a battery
hi you could go to your local supermarket or even go into your locall electronics store
Apr 15, 2010 | Forfex FX 652 Hair Trimmer
My HP Pavillion PC is new but It show Plugged in, not charging. Why?
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
The laptop will be under warranty, take it back to the supplier to get it fixed or replaced.
Mar 14, 2010 | HP Pavilion zd8000 Notebook
Forfex Babybliss trimmer
take off the blades undo the two allen screws this will let you see the brass drive shaft when you turn the power on the brass arm should spin to drive the blades if it does not spin scrap clipper but could be not locating in the hole in the top blade clean out and try
rgards
Dave
May 19, 2008 | Forfex FX 785 Hair Trimmer
Replacing battery in forfex fx652
Hello, where did you get the replacement battery????
Apr 04, 2008 | Forfex FX 652 Hair Trimmer
Forfex FX 652 Hair Trimmer Logo
795 people viewed this question
Top Forfex Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
