Question about Gestetner Office Equipment & Supplies
Gestetner DSM635sp paper stuck error.The machine throws the error and then stops. there is no paper that is ever stuck. Thanks for your help.
    President:
  • Gestetner Master
  • 990 Answers
Hello sir; There should have a paper stuck over the pick up roller that you can't see if you pull out the tray paper should be squeeze together. the solution way is replace paper pick-up roller.
Posted on Oct 02, 2009
Memory is full
call an expect to fix hard drive on the machine and this problem is over
Feb 12, 2013 | Gestetner DSm620d All-In-One Laser Printer
Where I can download drivers from the machine DSM635sp GESTETNER Thank You Jorge
Hello!
Gestetner is made by Ricoh. They only change the name. The cross reference for your model is Aficio 2045e.
You can download from the www.ricoh-support.com the driver of Aficio 2045e and your done.
Hope this helps you.
See you!
Jun 23, 2011 | Gestetner DSm635sp Digital Imaging System
How do you add an e-mail destination to the DSm635sp Gestetner printer/copier/scanner?
You have several posts here that tells you how to do it.
Just make a simple search and you will find it.
May 03, 2011 | Gestetner DSm635sp Digital Imaging System
Need to cancel outgoing fax, tells us it could not be cancelled
Have you made sure you have the correct paper size in the paper trays or have you tried to use the by pass tray, to let the fax error to go throw
Apr 05, 2010 | Gestetner DSm635sp Digital Imaging System
Faxing with Gestetner DSm 635 sp Copier
There is a fax module that you can purchase to be able to fax from the copier. If it is already installed, you will see two phone jacks on the rear side of the machine. One will be labeled "Line" and one will be labeled "Tel" -- if you plug a phone cord from the jack in the wall to the jack labeled "Line," your copier is all ready to fax.
On the operation panel, there should be a button on the left labeled "Fax" under the buttons labeled "Copier" and "Document Server" -- press that button to get to the fax screen.
Hope that helps!
Feb 05, 2010 | Gestetner DSm635sp Digital Imaging System
I have a Duplo DP 43s which is displaying "paper jam at the ejection end" error message. Can't find anything at all stuck in the machine but the sheet passes just past the drum and then stops, so causing...
i don't know if duplo is same as the gestetner type of digital duplicator. try to look if the exit sensor is clean or in good condition and if the paper coming out in a normally manner what i meant is if it is flowing normally.
Nov 29, 2009 | Duplo Office Equipment & Supplies
Gestetner CP6123 giving error E12
You should check the all paper sensor, there must be a pieces of paper in some sensor and make the sensor in wrong direction. You should remove all and off the power for a while and the start to use it.
May 11, 2008 | Gestetner - AO40 Wide Format Copier Copier
61 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
