Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Kenmore Bottom Freezer
I have a Kenmore refrigerator model # 596.71274101. I need a compressor fan motor part # 10522105 but I am unsure of the connection on the parts that are online. My fan motor has a white plastic plug on the electrical connection that I must have on the new part. Does this part come with this connection or is it shipped with bare wire? I have seen it online but it always shows it with bare wire without the plug connection. My freezer is not getting as cold as it should be. I took a look at the condensor fan and it was not working while the unit was running. I touched it with my finger and it began to spin in my opinion slowly. I think this is the problem but the connection for the fan worry's me.
  • djs30 Dec 21, 2007
    I will try the above. Just to add a little more if anybody has any thoughts as to why the freezer is no longer as cold as it should be. As I have stated I don't think the condenser fan is working properly but i'm not convinced this is the problem. The condenser is running and the coils in the freezer are not frozen. When I looked at them there was only some slight frost ...maybe and inch from the top down....on the upper right portion of the coils. The fans inside are running. The condenser and coils under the freezer....freezer on bottom....are warm but not hot to the touch. When the unit is running it has always been kind of noisy. Sometimes is sounds like it is speeding up and slowing down....like a whirling noise....but randomly at different sounding speeds. It has always done this....when it was working fine and now. I have read so much on the internet about this problem I am torn as to what the problem really is. I am going to take the back panels off again and place a fan blowing on the condenser and coils to see if that makes a difference, and to kind of take the place of the faulty fan. Any suggestions?
  • 833 Answers
Djs...some service parts, as they are called do come without the connector. The good news is that you CAN do this. When you get your part, unplug your fridge from the outlet. Remove the plug from the fridge harness and remove the old motor. Verify that the mounting holes or brackets will fit. If so, cut the wires about 2 inches from the end of the plug. Strip them and twist them each together tightly with a motor wire. It is unimportant which of the two motor wires goes to which plug wire unless there are more than two wires...which I doubt. Push the pigtail over the length of one of the wires and tape securely, stretching the tape. When you restart your unit, have a look at the compressor. The large pipe should frost over, then clear after about 5 minutes to ice, dry or wet. If it stays frosty...it means low gas which can cause cooling issues. Clean the condenser while you're at it. You should be fine.
Posted on Dec 21, 2007
  • Robert Hirst Dec 23, 2007
    Okay, if you have access to the coils in the freezer, you can determine exactly how the unit is working. You should have a light frost all the way across the coils...end to end...after about 5 minutes. If you're watching, you should see it happen. If it only goes part way...that is where the liquid refrigerant is no longer sufficient to continue boiling into a gas. You will need to have gas added so that it happens that way. Be sure that you don't have iced up coils...they are the ones that don't cool. Hope this is clear.
Need info for a kenmore side by side refrigerator model#59652673202 it it not cooling nor freeszing ; the light works and the fan works but not cooling any side please help me
Good day,
With that amount of info it would be hard to try to pinpoint it. Here's a list of items that can cause a refrigerator to not cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see it could be one of many,many items. If your handy with a meter you might want to start at the bottom back of the machine where the compressor is located.
Sounds as if it is not running, or running without refrigerant in the system.
Also, if it has a cooling fan motor in that area, make sure it runs, since all fan motors are wired to run at the same time.
Oct 15, 2010 | Kenmore 44103 Side by Side Refrigerator
The panel separating my side by side refrigerator from the freezer is hot - nearly to the point of burning. Kenmore model 10653606202
  1. check if the evaporator fan motor is running (inside the freezer)
  2. Same for the condenser fan motor on the bottom in the back of the fridge
  3. Clean condenser coils underneath or in the back of the fridge
  4. if there is a frost on the back wall in freezer - you've got the defrost problem, check defrost heater, defrost bimetal thermostat, and defrost timer
Oct 14, 2009 | Whirlpool GS6SHAXLS Side by Side...
What is proper operating temp of freezer/refrigerator?
0-5 F in the freezer.36-42F in fresh food.
Check for ice buildup on the back wall of the freezer. Check the freezer fan motor. Check the compressor fan motor.
Sep 06, 2009 | Kenmore Refrigerators
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer is fine. Fridgerator portion does not cool .
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Nov 21, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore model 59675502400
if the evaporator is clogged with ice, then you have a defrost problem.
check the defrost heater and the bi-metal .
to answer your question what controls the fan then it is the module that controls the fan.
you said you have diagnostic to test the damper then there should be a procedure also to test the evaporator fan motor.
why don't you try it..
tnx 4 using fixya,
drcool
Aug 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 596.755 23400 problem with freezer
You can try to replace the relay and overload but on this model usually the compressors go bad. Call sears to check the warranty. The compressor should have a five year warranty.
May 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Refrigerator Model #795.75004401 Doesn't get cold
Hi. Make sure all your fans are working. When checking fans, open the door and push the light button in. Some models the fan stops or dampers close when the doors are opened. Put your hand in front of the vent and see if you feel air. Do the same in the refrigerator and freezer. If you feel air from both, check and see of the compressor is running. There is a fan next to the compressor and should be running when the compressor is running. You have a motherboard behind a cover on the back of your refrigerator that controls all of these functions. It could be defective. Motherboard failure is common as well as compressor and evaporator motor failure. Fan Motor failure is common for refrigerators in storage for a long period of time. The motors are weak and can't start. This goes for all new refrigerators. I sell refrigerator items on Ebay as username, themackshack. Good Luck, Mack
Jan 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Dec 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore fridge
First we need to see if the compressor is running.  Pull the fridge out take off the lower panel on the back and see if you can hear it running.  Also, need to know if freezer fan and fan by compressor is running.  Check for thick frost build up on back panel in freezer.  Let me know what you find.
Oct 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
138 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
