Question about Adaptec ASH-1205SA PCI 2 POrt Serial ATA Controller (2047700)
Motherboard has two built-in Sata connectors. after installing controller I can either use the onboard connectore or the controller but not both.
  • 380 Answers
Check the BIOS settings. You may want to try AHCI settings or RAID settings and turn off LEGACY settings. The ports are controlled by the board itself, which is handled by the BIOS. So, the best place to start is there.
Posted on Oct 01, 2009
Install cd drive
Dell Optiplex 740 DESKTOP?
http://support.dell.com/support/edocs/systems/op740/en/UG/dt_index.htm
Under the bold black subheading -
Removing and Replacing Parts, click on - Drives, in the list.
After details on the power cable, and data cable, the Optical Drive is the first drive listed.
Examples of a SATA data cable, and it's connector; and a SATA data cable connector on the motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening in the SATA data cable's connector.
Lines up with an L-shape on the motherboard connector.
ONE style of SATA motherboard connector is shown.
Your SATA motherboard connector may differ in appearance. Still has an L-shape in it, though.
(Hold the SATA cable connector in your hand, look at the connector.
If you turn a capital L to the LEFT, and turn OVER, that is the correct position to install the cable, in.
_____I, then turn over )
SOME SATA cable connectors have a Lock on them.
Some are like a tab you press down, others are like a small 'bulb, that you press down on. Suggest use your thumb.
Depress Lock to Install cable, and to Remove cable.
Between a SATA data cable's connector, and a SATA power cable's connector; a SATA power cable connector is Larger.
SATA data cable connector has 7-pins.
SATA power cable connector has 15-pins.
Example of a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Depress the Drive Release Latch, slide the drive towards the Back of the computer, lift up slightly to remove SATA data cable, and SATA power cable; THEN remove optical drive.
(CD/DVD drive)
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 18, 2013 | Dell OptiPlex 740 PC Desktop
P3 DVD connector
Well........................
The numbering for power supply cables, differs from one pre-built computer manufacturer, to the next.
GENERALLY, a P3 power cable is a 4-pin Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
(Also misnomered as a 'Molex' power cable.
Molex came out with the design for the power cable CONNECTOR.
The name stuck. Kinda' like calling an adjustable open-end wrench, a 'Crescent wrench' )
A P4 power cable is usually a 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This power cable was brought out to provide more power for the motherboard, and specifically the Processor. (CPU)
Does NOT connect to an optical drive. (CD/DVD drive)
DOES need to be connected to motherboard though, because it is POWER for the Processor!
Moving on.............
Let's dispense with the antiquated numbering of the power cables, and show you the real information you need;
There are two types of Optical Drives out there, currently being used;
1) IDE. Also known as PATA.
2) SATA
An IDE optical drive will use a 4-pin Peripheral power cable,
Note the rounded corners on top.
When plugging in one of these power cables, just always remember the rounded corners go on TOP.
The data cable used is a flat IDE ribbon cable. These are general examples,
Illustration,
http://en.wikipedia.org/wiki/File:Nappe.svg
Photo,
http://en.wikipedia.org/wiki/File:ATA_cables.jpg
I would like you to look at the connector end, and specifically the Locating Lug on one side of the connector,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
This style of Locating Lug consists of two small 'bars'.
There are types where it is filled in. Just one solid lug.
The Locating Lug lines up with a Cutout, on the optical drive.
(Or IDE/PATA harddrive)
IF, there is no Locating Lug on your IDE/PATA flat ribbon cable, post back in a Comment.
I will show you the proper way to connect it, using the Red stripe on the side of the cable.
http://en.wikipedia.org/wiki/Parallel_ATA
If you have a SATA optical drive, it uses a SATA power cable.
This is a general example,
Between the SATA data cable connector, and the SATA power cable connector; the SATA power cable connector is the larger of the two.
SATA data cable connector has 7 contact pins.
SATA power cable connector has 15-pin.
This is an example of a SATA data cable, and it's respective connector,
Note the L-shaped opening. The SATA power cable also has this L-shaped opening.
Observe the SATA data cable connector examples, on the motherboard.
Note the L shape.
(Note: The SATA data cable connectors on YOUR motherboard, may differ in style.
The ones shown (Red) are an Open design.
There are styles that are Enclosed. Have an oval around the
L shape)
To install the cable connector, line the L-shaped opening, with the L shape on the optical drive connector.
Tip: Turn this L over to the left, then turn upside down.
The small 'foot' of the L, always points DOWN, when installing connector.
The SATA data cable connector, that plugs into the optical drive, should be a 90 degree bent elbow.
The connector end that plugs into the motherboard, should be a Straight connector.
The SATA power cable connector, and the SATA data cable connector; MAY have a Lock on top.
Usually a small depression, or Tab, or 'bulb'.
Depress with your thumb tip, to install, or remove the cable.
(Hmmm, betting now the P3 power cable may be a SATA power cable.
How'd I do? Post back in a Comment)
Regards,
joecoolvette
Jan 02, 2013 | E-Machines eMachines Desktop PC
Connections to the hard drive
The Harddrive is a SATA unit.
Uses a SATA data cable, and a SATA power cable.
SATA data cable, and connector on motherboard, example;
Between the SATA data cable connector, and the SATA power cable connector; the SATA data cable connector is the shorter of the two in width.
The connector end used on the harddrive side, and optical drive side, (CD/DVD drive), is usually a 90 degree Bent Elbow.
The connector end that plugs into the motherboard, is a Straight connector.
NOTE* Color of connectors does NOT matter.
Most of the time the SATA data connectors on the motherboard, are different colors.
This is to help discern what number of SATA data connector it is.
Four SATA data connectors on the motherboard?
SATA 1, SATA 2, SATA 3, and SATA 4;
Or:
SATA 0, SATA 1, SATA 2, and SATA 3?
SATA 0, or SATA 1, is usually reserved for the Harddrive.
The Primary harddrive with the Operating System on it.
(Unless you have harddrives set in a RAID configuration)
DOES NOT MATTER WHAT SATA DATA CONNECTOR, you plug into, on the motherboard.
Want to plug the harddrive into SATA 3, or SATA 4?
Go ahead.
NO matter what SATA connector on the motherboard that you plug into, BIOS will find the harddrive.
Note the L-shape in the connector.
Has to line up on the L-shape on the harddrive, optical drive, or motherboard, SATA data connector.
There is usually a lock on the connector. This you may not see.
Sometimes there is a little 'bump' on the connector. Depress with the thumbnail to install the cable, or remove.
This is an example of a SATA power cable,
NOTE*
IF, your SATA harddrive has a provision for plugging in a SATA power cable, AND a 4-pin Peripheral power cable; ONLY plug the SATA power cable in.
Using BOTH types of power cables will BURN the harddrive up.
May not happen right away, but I assure you it will happen.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/SATA
Dec 10, 2012 | Acer Aspire X1 AX1470-UR11P Desktop PC...
Dell t3400 power for 2 hard drives
Not a problem.
This is a general view of a SATA -> data cable, and it's respective connector on the motherboard,
Note the L-shaped opening in the SATA data cable's connector, and matching L-shape on the SATA data connector on the motherboard.
Note also that a SATA data cable's connector has 7-pins
Between it, and a SATA power cable connector, the SATA data cable connector is the smaller of the two.
A SATA power cable has 15-pins,
Note that it's cable connector opening is also L-shaped.
So is the matching connector on a SATA harddrive, or SATA optical drive. (CD/DVD drive)
A SATA power cable's connector generally has an area on it, that you depress with your thumbnail, and this releases a Lock.
Depress to install, depress to remove.
SATA data cable connector, Or SATA power cable connector; that goes to a Harddrive, or to an Optical Drive, is usually a 90 degree bent elbow.
The straight connector on the cable plugs into the motherboard.
(Can be straight connector on both ends through, but isn't CORRECT)
SATA connectors on motherboard;
IF, this Ebay link selling a Dell Precision T3400 Desktop PC motherboard, is correct, there are;
http://www.ebay.com/itm/Dell-TP412-Precision-Workstation-T3400-Socket-775-Motherboard-/360503300257?pt=Motherboards&hash=item53efabd0a1
1) FOUR Black SATA connectors
2) ONE White SATA connector
3) One Blue SATA connector
1 Black SATA connector, and 1 Blue SATA connector, at the bottom of the black Ram Memory slots.
1 White SATA connector, and 3 Black SATA connectors, right next to the where 24-pin ATX main power cable, plugs into the motherboard.
General example of said main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Note* Color of connectors does Not matter )
Originally the Master harddrive, should plug into SATA1 connector on the motherboard.
If you look real close, next to all of those SATA connectors on the motherboard, you may see SATA0, SATA1, SATA2, SATA3, SATA4, and SATA5, printed right next to them on the motherboard.
The beauty of SATA:
DOESN'T MATTER WHERE YOU PLUG IN WHAT, on those SATA connectors.
Use ANY one you wish, and plug whatever SATA device into it, that you wish.
BIOS will find the SATA device.
No matter what SATA connector you plug into, and no matter what SATA device.
Kapish?
http://support.dell.com/support/edocs/systems/wst3400/en/ug/ug_en.pdf
What a minute, this news just came in.............
The Blue SATA connector on the motherboard, under the black Ram Memory slots, is SATA0.
The Black SATA connector next to it is SATA1.
If you have SAS harddrives (Serial Attached SCSI), the power cable's connector has a provision, to plug the SATA data cable into it also.
If you do not have that particular SAS power cable it's OK.
You can just use a separate SATA power cable, (90 degree elbow to harddrive/optical drive), and a separate SATA data cable.
For additional questions, or to have me clarify further on anything I have stated above, post in a Comment.
Regards,
joecoolvette
Oct 30, 2012 | Dell Computers & Internet
How do i install a wdeads hard drive? where is the power supply (4pin Molex)?
I'LL TELL YOU UPFRONT i HAVE ONLY INSTALLED SATA ON A NEW SYSTEM SO MY ANSWER MAY NOT BE CORRECT IN ALL SITUATIONS
Question is vague. Are you replacing a drive or building a new system? SATA drives have a dedicated plug on the Mother Board. Of course you already know you can't replace an IDE with a SATA without an adapter (Ebay has them for about $8) or the Bios is incompatible. The power is on the Motherboard and does not have a connector from the power supply like an IDE has.
Feb 20, 2011 | Western Digital WD15EADS 1.5 TB SATA Hard...
Install IDE devices (drives / DVD / CDROM) sata
IDE devices have different "data" and "power" connectors than SATA drives.
So, you need a motherboard with IDE connectors, if you wish to connect an IDE disk-drive (or CD/DVD), and you need a motherboard with SATA connectors, if you wish to connect a SATA device.
Similarly, the connectors on the power-supply must be compatible with the sockets on the disk-drive (or CD/DVD) drives, so that the devices can get power.
You could possibly purchase a short IDE-to-SATA power-adapter, if you have a SATA device, but there are no SATA power-connectors on your power-supply.
May 29, 2010 | Intel Motherboard
Installing
I couldn't find illustration, but you'll need SATA cable and 4 small orange/yellow connectors in the corner of motherboard are your SATA connectors.
Apr 26, 2009 | Computers & Internet
Motherboard
Part / Feature Specification / Support Motherboard description
  • Motherboard manufacturer's name: MSI MS-7174
  • HP/Compaq name: Graphite-GL8E
CPU/Processor
  • Socket: 775
  • Supports the following processors
    • Pentium 4 600 series
    • Pentium 4 with HT
    • Celeron D
Front-side bus (FSB)
  • 800 MHz (Pentiums)
  • 533 MHz (Celeron D)
Chipset
  • Northbridge: i915GV
  • Southbridge: ICH6
BIOS features
  • The mainboard BIOS provides “Plug & Play” BIOS which detects the peripheral devices and expansion cards of the board automatically.
  • The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Form factor
  • Micro-ATX form factor: 9.6 in x 9.6 in
Memory
  • Dual-channel memory architecture
  • 2 x 240-pin DDR2 DIMM sockets for up to 2 GB non-ECC DDR2 533/400 SDRAM
  • Maximum HP/Compaq approved memory is 2 GB
Expansion slots
  • Three PCI
Video graphics
  • Integrated
Serial ATA
  • 2 SATA connectors
  • Each connector supports 1 serial ATA-150 disk drive
Onboard audio or audio card Integrated Intel High Definition(TM) audio (Azalia)
  • Realtek ALC 880 CODEC
  • THX certification support
  • 8-channels for Full Dolby 5.1/6.1/7.1 surround sound support with Dolby Pro Logic IIx
Onboard LAN
  • Intel 82562GT
  • 10/100Mbps Fast Ethernet LAN controller
Back panel I/O
  • One PS/2 mouse port
  • One PS/2 keyboard port
  • One VGA (monitor)
  • One Parallel
  • Four USB (2.0)
  • One IEEE 1394a
  • One RJ-45 networking port
  • Six audio ports support 8-channel Azalia audio codec
  • One S-video out
  • One SPDIF in/out
Internal connectors
  • One 24-pin ATX power connector
  • One 4-pin 12V ATX power connector
  • One IDE connector
  • Two SATA connectors
  • One floppy drive connector
  • CPU fan connector
  • PC fan connector (also known as duct or chassis fan)
  • PC indicator LEDs / power switch / reset button connector
  • Optical drive audio input
  • Auxilliary audio input (may be used for line input)
  • Front panel headphone and microphone connector
  • Two USB headers supporting up to 4 additional ports or devices
  • One IEEE 1394a header supporting one 1394a port
Jul 27, 2008 | Compaq Computers & Internet
Internal DVD Drive
if you,ve purchased a SATA drive.
Then you should have SATA Connectors On The Motherboard.
If you look carefully you should see SATA1 And SATA2 if applicable. they,ll look like a small black/white piece of plastic connector. shaped similar to a letter *L* this is the sata connector, you may already have a hard-drive on 1 of them. ( red Cable ) The 4 pin audio cable, goes from the rear of your DVD Drive, you should have 2. 1 for analogue 1 for digital. this connects Audio from your Drive to motherboard, slim grey cable ( usually ) look towards the rear of your motherboard for this, usually towards the audio out ( if you have onboard soundcard )
connect this to Audio/sound ( you,ll probably have 3 located close together.
Hope this helps.
Mike @ Compurepair.
Feb 11, 2008 | Computers & Internet
Adaptec ASH-1205SA PCI 2 POrt Serial ATA Controller (2047700) Logo
126 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Robert Graf
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
