Question about Electrical Supplies
Engine running at 3600 rpm i get 0.51 volt reading from all scocket outlets
  • 98 Answers
Check your volt-meter..if it works...then find out if 3600rpm is normal for that kind of generators...if so...check AVR card...its allways the problem...replace it
i hope i helped...send me an email for more details
Posted on Oct 11, 2009
Engine and battery light comes on when riding
Hi Dolan, check your battery terminals for clean tight connections. Hook up a volt meter too your battery and run the engine up to 3600 RPM your meter should read 14.3 to 14.7 volts DC if it much lower you have a charging system problem. If it reads ok then do a load test on the battery or charge it overnight to get a reading of 12.5 to 12.8 Volts if much lower replace battery. Good luck
Mar 22, 2014 | 2009 Harley Davidson FXDF Dyna Fat Bob
Engine and battery light come on
Hi Anonymous, check your battery terminals for clean tight connections. Hook up a volt meter too your battery and run the engine up to 3600 RPM your meter should read 14.3 to 14.7 volts DC if it much lower you have a charging system problem. If it reads ok then do a load test on the battery or charge it overnight to get a reading of 12.5 to 12.8 Volts if much lower replace battery. Good luck
Mar 21, 2014 | 2009 Harley Davidson FXDF Dyna Fat Bob
Battery not charging while running
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Jan 19, 2014 | 2000 Harley Davidson FXDX Dyna Super Glide...
Charging system failure low voltage
Jan 07, 2014 | 2011 Harley Davidson FLHTK Electra Glide...
2000 hd flhtcu doesnt charge battery when running
Apr 10, 2013 | 2007 Harley Davidson FLHTCU Ultra Classic...
Homelite LR 4300 generator only supplying 230v, even at the 120 outlets
Make certain the voltage switch is set to 120 volts, not 230 volts.
If you lost your user manual, you can download on in the link below. Just click on the "open as PDF" button and it will download t your computer. http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/electric_generator.html?p=16
Dec 20, 2017 | Electrical Supplies
Engine light and battery light
Hi Kellyafurlon, perform the following tests:
Jun 30, 2012 | 2007 Harley Davidson XL 883 Sportster
I have a 2001 flhtcui what are the ac reading coming from stator at 2.5k rpm 3k rpm and 3600 rpm. At 2000 rpm I get about 12 volts dash guage reading but at 3000 I get 13.5 to 14 at lower rpm 2000 or so I...
The AC output of the stator should be 32-40 volts at 2000 RPM (16-20 per 1000 RPM). With the battery fully charged, your regulator should supply between 13.5 and 15.0 DC volts to the battery. This should be the reading you get on your voltmeter. It will vary depending on what lights and other equipment you have turned on. Sounds like everything is working fine to me. The gauge is reading the DC voltage at the battery while the engine is running. At 2000 RPM, 12 volts is a little low but, considering the accuracy of the gauge, as long as it doesn't fall below 12 volts, it's about right. You don't ride for extended periods at engine RPMs that low. Then at 3000 RPM, 14 volts is about right. If your bike never ran anymore than 12 volts, your battery would slowly go down. If it goes any higher than 15.0 volts, it will boil the battery. Usually, about 14.3 or so with no load on the system is about right.
Good Luck
Steve
May 17, 2011 | 2001 Harley Davidson FLHTCUI Electra Glide...
Model pm0525312.18 serial 914080230 engine runs good but the voltage drops of from about 125volts to 90 volts when you put on about 1500 watts. does this model have a voltage regulator? what is a bridge...
According to the parts pdf, there is no voltage regulator. Voltage is adjusted by the rpm of the engine. If your have a meter that reads hertz (Hz), you can set the engine rpm by adjusting hertz to 60 cycles (Hz). At 60 cycles the engine is running at about 3600 rpm. Most engines develop their max horsepower at this rpm. If you are loosing power/voltage and the engine speed is not dropping below 3600, than most likely could be problem with capacitor, brushes or diode (bridge diode). The diode converts ac voltage from stator to direct current to power the magnet (rotor). Check for brush wear and test capacitor for value printed on part. It should test with 5% of stated value. Diode can also be easily tested with meter. Good holidays
Dec 05, 2010 | Coleman Powermate Powermate 5000W...
I have a coleman 5000 that won't hold voltage at 110 volts under load. It fluctuates up and down. The motor is running steady. What could be the cause of this?
govenor problem maybe does the engine sound slower when a load is on.
you will need something to read the power frequency
3000 rpm produces 50hz uk
3600 rpm produces 60hz
so if you have a meter to measure frequency you will also know what speed the engine is running at
Feb 27, 2010 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
