Re: 96 chrysler Lhs when i take my foot off the gas
Idol air controler keeps car running at idol speed ,you can take it off and clean it with throttle body cleaner to get carbon off its located on throttle housing ,if this works or improves your problem at all get a new one...
I think many of these systems can be reset by hooking up battery, turning the key to "ON" but not to start, wait 15 minutes, turn key off, then try to start.
I suggest that you go to ALLDATA.COM and take out a subscription for ALLDATADIY, this access can give you unlimited knowledge about your vehicle. I have a repair manuel also between the two reference media I have solved most of the problems you are facing. Not to mention the problems you will be facing with a vehicle this old.
Sounds like you have a broken wire. Check the wires under the fuse panel under the hood. Its a problem with Chrysler mini vans and it might be the same here.
IF IT WAS A FUEL FILTER IT WOULD ACT LIKE THIS ALL THE TIME. GO TO AUTO ZONE OR ADVANCED PART STORE AND THEY WILL SCAN IT FOR FREE.BECAUSE IT COULD BE A EGR VALVE STICKING OR A THROTTLE POSITION SENSOR OR A {A.I.S MOTOR].
