Question about Maytag MHWE300VW Washer
I'm building a pedestal for the Maytag Mhwe300vw washer. I have been told that the dimensions should be 27" X 31.5" depth. However, the front of the machine is bowed which brings it to 31.5" in the center. My question is what are the distances between the adjustable legs?
    President:
  • 1,304 Answers
Dont wory about the bow
the legs are on a square
consider it a 27" square
but you will regret putting it on a pedistal
Posted on Oct 05, 2009
What size washing machine is this
Your Maytag Neptune MAH6500A Front Load Washer has dimensions:
Width : 27"
Depth : 29"
Height : 42 1/2"
Capacity : 3.34 cu. ft.
http://www.ajmadison.com/cgi-bin/ajmadison/MAH6500AWW.html
May 22, 2014 | Maytag Neptune MAH6500A Front Load Washer
Frontload Washer MHWE300VW 4.0 Is a rear tub covered at all past the one year standard warranty?
Hello, Thank You for using FixYa. I will be helping you today.No.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Maytag MHWE300VW Washer
Need exact dimensions of duet washer & dryer bought in 2006. Also how to prepare for moving same appliances.
Basic measurements for washer and dryer with door closed and not on optional pedestal(s) are 31.5" deep (front to back), 27" wide, (left to right), and 38" high. For installation and usage consider the leveling feet, use of pedestal(s), water hookups, drain hose for washer, and vent (exhaust) hose for dryer. You may want to position the washer on your left, and the dryer on the right due to hinge location, and for ease of transferring laundry from one machine to the other. Depth of washer (front to back) with door open 90 degrees is 50.5" and the dryer is 51.5". At the factory, four (4) shipping bolts are attached to the back of the washer to secure the drum for shipping. These should be re-installed prior to the move, (if you still have them). To see the supporting documents, go to; http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/ewpl_mic_604_021.pdf
I hope this helps you as well as others. Please rate my answer. Handiest1. 10-1-10
Oct 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Installing pedestal to washer
You want to level just the pedestal in the place where you will be using it so when you put it in position mounted together later it is done. Also very easy to do first. Get the pedestal level, tighten the lock nuts, put the washer on its back. Usually you remove the washer feet, take the pedestal drawer out, screw on each side, bolt the pedestal to the washer with the four screws provided. Tip pedestal and washer up, on to something that slides easily to protect floor. There usually are some type of shipping bolts that have to be removed from back of washer before using on new units. Usually four and these have to be removed.
Jan 13, 2010 | Maytag EPIC MFW9700S Front Load Washer
How do I level my machine with an accessory drawer underneath?
Do not try to level the washer. Level the feet on the pedestal AFTER the washer is installed. Just make sure the legs of the washer are all set the same on the pedestal and tightened down. Then, adjust the pedestal feet so the washer is level front-to-back and side-to-side. Once you level the unit, place your hands at opposite diagnoal corners on the top of the washer (one hand on a rear corner, the other hand on the front corner). If the washer has a firm foundation and you have the leveled the feet correctly, it should not move when you apply any pressure at these opposite corners. If you have questions, please let me know. I hope this helps you.
Nov 23, 2009 | Maytag EPIC MFW9700S Front Load Washer
Terrible vibration on washer
make sure your locknuts on your pedestal are tightened all the way up
Apr 15, 2009 | Maytag MAH8700AWM Neptune Front Load...
Fridgidaire FTF2140ES0 Front Load Washing Machine Vibration
Try going to GVIINC.net - there product definately works.
Nov 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag MHWE300VW Washer Logo
298 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
