Question about Video Game Consoles & Games
I have the hipstreet wireless remote for the ps3 but not matter what i do i cant seem to get the remote to work
Hipstreet mouse hs-wmso2 wont work with windows 10
Did you try removing the USB receiver on the computer, powering down, powering back up and then inserting the receiver so that Windows knows you have a 'new' device.
Also Control Panel, Hardware and Sound, Add New Hardware.
There is a Hipstreet chat facility here.
Contact Us
Dec 09, 2015 | Hipstreet Hip Street Wireless Keyboard and...
New play tv wont work via remote play on my psp
To make Play TV on the PSP via the Remote Play work
watch the instructional video here
and detailed information here in full-color
be aware that this whole thing depends on the firmware version of both PSP and PS3
Sep 27, 2008 | Sony Playstation 3 (PS3) Console
Hipstreet Flare2 Frozen, How can I fix?
Frozen Screen Syndrome? Try holding the on/off button, while at the same time pressing Volume+. I've posted this solution for a number of tablets and it seems to have worked for most tablets!
LindaSView
Apr 24, 2014 | Hipstreet Tablets & eReaders
My ps3 seems to b working fine but i cant see anything. no matter which tv i plug it into it says that there is no signal
Hi aztecruler12,
For you to be able to see a picture on the screen you need to make sure that you're on the right input. Inputs on your televsion depends on the cables that you are using. PS3 supports HDMI and Component Cable (Blue/Green/Red). If you're using HDMI Cable to connect the PS3 to your TV then you need to select HDMI Input and if you're using a Component Cable it should be Component Input. To change the input you need to use the original remote of your television. Look for Input or Source button and select the input depends on your cable.
Rate me if this helps so i can help others. Thanks for using Fixya.
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
Sony PS3 wireless keyboard non responsive only blinks green light
Hit the Reset Button on the Keypad (Its a little hole on the left of the back). It works all the time.
Apr 25, 2009 | Sony Playstation 3 Wireless Keypad/Mouse
Ps3 controls not connecting
If they work wired and not wirelessly then you might have a problem with your wireless access module. Can you access the internet through your PS3?
Feb 20, 2009 | Sony Playstation 3 (PS3) Console
Turning on PS3 causes home wireless network to stop working
I have the same problem. My router is located about 1.5 feets from the PS3 and when I turn on the console my wireless network barely works. Something I did was change the frequency of the wireless. It was working in channel 9 and now it's on channel 3 with no problem.
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
Bad connection for wireless internet
There isn't really going to be a "best" wireless Internet service. You just want the fastest that's available to you. Usually that's cable or DSL. I would recommend going with a wired connection instead of wireless, you will have a lot less of these issues. Good luck!
Jan 08, 2009 | Sony Playstation 3 (PS3) Console
Wireless controller problem
Its not a memory stick! its a radio reciever that you need with the controller.
The remote bundled along has a seperate one.
Just make sure the switch on the dongle is set to PS and not PC (as can be used on a pc aswell)
Art
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
369 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
