Coleman Mach III Air Conditioner
Problem for Coleman Mach III Air Conditioner
Coleman mach fan runs fine but A/c hums intermittently
By nicolmw on Oct 01, 2009
Coleman mach fan runs fine but A/C hums intermittently like it wants to start but won't. I'm running it with a Honda 2000 generator. Generator ran out of gas, when I restarted the generator the A/C would not run - stalls out the generator. I replaced the start and run capacitors on the A/C, hook up the generator and it ran fine until the generator ran out of gas. The A/C would not start up only hum intermittently - same problem as before replacing capacitors. Waited several hours with the fan only and tried tyo switch on the A/c still would not start. Any suggestions on what to do next?
Solution #1
posted on Oct 01, 2009
Somewhat Helpful)
alenorm
Rank: Wiz
Rating: 84%, 179 votes
The issue with the generator that gets low and high when it start running out of gas that effect the A/C and result of high voltage getting to the unit and burn the capacitors and it should by saved by the fuse make sure that the gen not run out of gas if you have the A/C on and that the fuse is the correct one for the A/C and again check the air and see you may got a bad capacitor.
....let me know if that work for you and please do not forget to rate my service so I am able to continue providing same...god bless
1 thump not related
2 thump related but no recommendation
3 thumps related worked some issues
4 thumps related worked all issues and satisfied
Was this helpful?
Yes
No
Popular Solutions for Coleman Mach III Air
Questions and Unsolved Problems for Coleman Mach III Air
Do you recommend Coleman Mach III Air Conditioner?
Answer
Answer
Replaced condenser and had health problems. Now cant find wireing diagram to reinstall. Thank youfor... (More)
Answer
installing to volvo 36ft bus need installation requirements for water drainage, electrical and... (More)
Answer
water is entering through unit. i think the previous owner sealed around weep holes. how do i fix or... (More)
Answer
I have a coleman top unit in my travel trailer the wires running from the thermostat are red green... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
in , CA
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
