Question about HP Office Equipment & Supplies
How to use scanner with HP Officejet J4680...scans as a pdf. want it to scan as jpg but can't figure out how!
SOURCE: HP Officejet J3640 All-in-One No Scan Options
When I triy to scan my document, I keep getting no scan options. Please help.
Posted on Dec 04, 2008
  • 2692 Answers
SOURCE: HOW TO SCAN HP J4680
Here is the HP support page for your printer where you may download an operators manual.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3692888&lc=en&cc=us&dlc=en&submit.y=5&submit.x=4〈=en&cc=us
Posted on Dec 26, 2008
ziraffa
  • 827 Answers
SOURCE: EPSON Scanner 4490 Problem
So you've completely ininstalled. Now you should download and install nCleaner, and do a Clean System, and then a Clean Registry. Now:
Download and install the latest 4490 driver software from here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=+ab4PwTTw7cRmkks+y0Lel8FKCE2A3PV7yPoa5gsU002FboU003D
The Epson Copy Factory Update may be of some use to you also.
Hope this helps
Chris (ziraffa)
Posted on Jan 11, 2009
SOURCE: HP officejet/HP officejet pro J4680
What do I do to ron Faxs from the top instead of the window?
Posted on Jan 14, 2009
melnavz
  • 1226 Answers
SOURCE: Scan to PDF File
You have to save your scan to PDF file type. after the system finished saving the file it will ask you again want to scan another pages. replace the page in the scanner and then click to continue.
the saving of file will on the next page of the first file name.
you're own your way.
melnavz
Posted on Jan 23, 2009
I want to scan to pdf on the hp 7310 all in one but it only scans to a file (jpg). How can I scan to pdf?
you will need to open a pdf creation program like adobe acrobat pro and scan while in that program. Then you can save it as a pdf. The scanning software will just scan it as an image.
Apr 20, 2011 | HP OfficeJet 7310 All-In-One InkJet...
How to scan with HP officejet J4680 printer
To scan from the device control panel (direct connect)
1. Load the original.
2. Press the left arrow or the right arrow to select the Scan function, and then
press OK.
3. Press the right arrow to select what to do with the scan, and then press OK.
4. Press Start.
Mar 15, 2011 | HP Officejet J4680 InkJet Printer
How do I scan a picture from the HP J4680 to computer
This is the step on how to scan docs using HP J4680:
    1. Press the "Power" button on the HP J4680 and lift the top cover. Place the document to be scanned on the scanner glass. Be sure the document is face down and properly aligned with the top, left-hand corner of the glass.
    2. Use the arrow keys on the control panel of the HP J4680 to select the "Scan" feature. Press "OK" to continue. Then Press the right arrow to select the scan feature. Press the "Start" button to begin the scan.
Dec 13, 2010 | HP J4680 Office Jet All-In-One Printer
My hp L7590 Not scan in Pdf. It only scan in jpg format. I want to scan multiple pages in one file so pdf or other option like .doc is needed but it will not scan. Message display your device driver is not...
The PDF File Type Is Not an Option When Scanning from HP Solution Center for HP Multifunction Printers When Using Windows
This document pertains to all multifunction printers with HP Solution Center software connected to a Windows computer.
When you scan from HP Solution Center in Windows, the PDF file type is not available.
Oct 10, 2017 | HP Officejet Pro L7590 All-in-One InkJet...
How to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Mar 02, 2010 | HP Officejet J4680 InkJet Printer
Just need the steps to scan, I've never used the scanner.
You need to open your scanner program up, you will see a window representing a Scanner Platen, Open scanner and place image Face Down on glass, and close lid. Now click on "Preview" this will scan the image and allow you to "Select" exactly what via resizable selection box, that you can grab with your cursor and set it to whatever you want to actually scan. Now click the "Scan" button, this time it will do a"Final Scan" and ask you where to save it, usually it is saved as a JPG, if other formats are available use whichever one you wish. may have JPG, BMP PDF. Save your image. Now you can use this image how you want. Also once a scanner is installed you can scan into say Word, or Adobe, Publisher etc. Document by using the scanner. A Twain driver is installed so it can communicate between applications.
Feb 11, 2010 | HP Officejet J4680 InkJet Printer
HP Officejet j4680 All-in-one: windows installer interrupts scan
kindly re install the printer driver.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Computers & Internet
How can I scan to a PDF file? I am using HP Officejet 5610 printer
To scan a document to PDF using HP Officejet 5610, try the following,
1.) Click the "Scan paper" icon to select HP Officejet 5610, and then scan documents from the scanner
2.) Click the "Build to One PDF" icon to create a PDF document contains all of the scanned documents.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 12, 2009 | HP Officejet 5610 All-In-One InkJet...
How do i scan a document and then email it
If you haven't done so, install the cd that comes with the HP Officejet package. Once correctly install, you should go to "All Programs" and locate "HP Solution Center" Click on HP Solution Center, click "Settings", click "Scan settings and preferences", choose either "scan document" or "scan picture" If word document then under File type: locate "PDF(*.pdf) If document is a picture then under File type: locate "JPEG image(*.jpg), click ok. Step 2 Choose between Scan Picture or Scan Document, click accept Step 3 your file is locate under "My scan" Hope that helps
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
366 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
