Question about LG Vu CU920 Cellular Phone
Whenthe screen goes white and itsays re-flashing
What to do when the screen goes white and it says re-flashing ?
Need replacement lamp for 2008 sony 52 inch KDL-52WL-135
A replacement lamp will not cause this, screen goes white to black and then to white (no picture I presume)
Dec 18, 2012 | Televison & Video
Screen flashes white then goes black
Sounds like a ribbon cable to the top screen maybe damaged. Upon startup, the ds does a systems check, any kind of failure e.g. a ribbon cable or a faulty screen would cause the console to shut down again. Presuming everything else works charging etc this is most likely to be the problem.
Sep 10, 2012 | Nintendo DS Lite Console
Nokia 6300 Memory Store Not Ready Then White Screen Appears
Bro. . Goto any mobile software shop and flash your mobile. This is software problem
Feb 25, 2012 | Nokia 6300 Cellular Phone
My screen goes white, and turns back on, then goes whit again
think its a goner....my daughters W810i did the same and i still have it. Someone said about flashing it but that didnt work either.
Feb 16, 2010 | Motorola Mobility Rival A455 Cell Phone
Screen loses picture after several hours of use. Volume works, picture comes back on after several hours?
Look at the venting grills on the back to see if you see any white lights inside the TV whenthe picture goes out, if no light at all, then the backlight inverter board may be going bad when it heats up, or it can be the power supply that supplys the power to the inverter board is bad. Take a look at the power supply to see if it has any bad capacitors, that is the easiest thing to do.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 11, 2009 | Insignia IS-LCDTV32 32 in. Television
RAZR V3 Screen flashes black and white
the firmware needs to be flash into teh phone take the phone to a mobile service center and have it fix.
Nov 25, 2008 | Motorola Mobility RAZR V3
Errors!
update java once shockwave player and flash windows update run ccleaner.com tool k
Oct 09, 2008 | Computers & Internet
Camera won't flash
Check your batteries and if that is not the problem, you have nothing to lose take off the back and see if the wire or some debris is obvious. If not your camera is just a parts camera then. Let me know how it goes
Aug 13, 2008 | Panasonic Lumix DMC-LZ5 Digital Camera
White screen
how do you flash the firmware using pc. can u tell the procedure
Apr 27, 2008 | Nokia 9300 Smartphone
LG Vu CU920 Cellular Phone Logo
104 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
