Cameras Logo
Anonymous Posted on Oct 01, 2009
SD card issues
Bought a Digi Elph sd630 bout about 2 or 3 years ago. What's the biggest sd card it will support? I was told the older cameras wont support a 16gb or 32gb.
Anonymous
Level 3:
  • Master 11,896 Answers
  • Posted on Oct 01, 2009
Anonymous
Master
Level 3:
Answers
11896
Questions
Helped
3734534
Points
36074
8 gigs
Testimonial: "Thanks!"
1helpful
Memory card error
What type and size memory card? The SD630 works with SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
If you are using an SD card, have you tried formatting it?
6helpful
Canon SD630 any sd card i put in it over 2gp says memory error
The SD630 works with MMC and SD cards, which max out at 2GB. Larger cards are actually SDHC cards and will not work in the SD630.
3helpful
2answers
4 gb memory card placed into camera. Camera says card error. Why?
The SD630 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in SD devices.
You need to use SD cards, 2GB and smaller.
1helpful
WHAT IS THE BIGGEST SIZE CARD AND WHAT TYPE FOR THE canon powershot SD630 ELPH?
The biggest size SD card compatible with Canon Power Shot SD630 is 1 GB. Visit canon showroom to buy SD card.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
10helpful
2answers
20helpful
Canon PowerShot SD 630 Digital Elph "Memory Card Error"
I'm sorry to tell that PowerShot SD 630 does not support SDHC cards over 2 gig.
If you want the camera to take a card over 2 gig then you are stuck standard SD cards.
The other camera does support the card because it's a higher model.
Regards.
Do not know how to transfer pictures
You need to buy an SD Card reader. They can be bought for at least $10 and will plug directly into a USB port on your PC
5helpful
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
