Question about Lexmark X5470 All-In-One InkJet Printer
Lexmark X5410 Printer won't recognize refilled OEM ink cartridge
I have a Lexmark X5410 Printer that will not recognize any ink cartridge other than a brand new Lexmark ink cartridge. If I refill a Lexmark cartridge or use a generic it will not recognize it and basically forces you to buy their ink cartridge. How can I overcome this so I can use any cartridge that I want?
My lexmark X5410 will not accept the black and colored refilled ink cartridges from walgreens. It keeps reporting that the right cartridge is missing.
If you have refilled the cartridges 28 and 29, it's pretty normal that your printer won't print. Those cartridges are not for refill (they can be refilled, but won't work once the printer says they are empty). If you have refilled a 28A and 29A and it doesn't recognize the one of the cartridges, try removing them and clean the electric contacts with a dry cloth. Put them back in. If that doesn't help, I suggest you buy a new cartridge.
Apr 11, 2010 | Lexmark X4530 InkJet Printer
My Lexmark X5410 Printer will not recognize a refill cartridge.
Hi there
This is the same old story with Lexmark printers, you cant do any thing about it the chips have a small fuse inside them and soon as they emty it blows the fuse, and thats it so I beleave the only way is to buy new ink, or a diferent printer.
Not know any fix for them myself sorry.
Can try.
Turn printer off. Unplug power cord and other cables. Wait 30 seconds. Plug cords and cables back in.
Also seen this on the net.
Use clear tape over left hand row of sensors on front of cartridge and re-insert. ink now shows with question mark but reads as full and prints fine.
but yeah, best bet, never ever buy lexmark.....:)
http://www.fixyourownprinter.com/forums/inkjet/35235
If that doesn't work, try disabling your ink monitoring software.
All The Best Pineworks
Feb 21, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark z54 won't recognize the refilled cartridge
Lexmark does not support the use of refilled or third party cartridges.
This is a statement of the quality of the ink and the concern for the damage that low grade ink can cause on print quality and product.
Please do not shoot the messenger, the above statement is true.
Don
Oct 21, 2009 | Lexmark JetPrinter Z25 InkJet Color...
Printer does not recognize carts
I have refilled my cartridges many, many times. A messy job, but well worth the savings. Never over fill, handle carefully.
The printer will give an error message, but just press cancel, do not order a new cartridge, Your refilled cartridge will work on the lexmark x5470. Good luck.
Oct 02, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x4850. swapped oem with non-oem black cartridge. will not print black now. message says warranty does not support non-lexmark and prints blank pages.
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 01, 2009 | Lexmark Office Equipment & Supplies
I cannot get my printer to recognize my refilled ink cartridges
Apr 20, 2009 | Lexmark X2500 All-In-One Printer
Cannot overide "wrong cartridge" message when using oem cart
Lexmark International does not recommend the use of third party inks or inkjet cartridge refill kits. Genuine Lexmark inks and cartridges are perfectly matched to the printing system. Using genuine Lexmark ink and cartridges ensures that every document produced is of the highest possible print quality, providing long-term dependable service from your Lexmark printer.
Lexmark cannot assure the excellent print quality and reliability of its inkjet cartridges after a cartridge has been refilled. Using incompatible inks in an attempt to extend the life of a genuine Lexmark cartridge beyond its recommended usage can cause failures in several different areas of the printer. Inkjet cartridges and printer failures caused by refilling or a third party ink are not covered by your Lexmark printer Warranty, Extended Warranty or Service Agreement.
Apr 13, 2009 | Office Equipment & Supplies
Refilled the black cartridge and now it doesnt recongize it
Apr 13, 2009 | Lexmark X5650 All-in-One InkJet Printer
I have an X5410 Lexmark printer and I'm trying to put in a black ink cartridge # 32 (It said this one is compatible with the printer) Every time I close it it says that the left cartridge is wrong. I...
Looks like the #32 and #33 are not compatible with x5410. Check this link for cartridges that will work with your specific model: http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
On step1 - "Choose your printer type", select "All in one"
On step 2 - "Choose your printer model" select "Lexmark x5410"
On step 3 - see the list of compatible cartridges.
If you bought the cartridges from the store see if they will replace it for you. If that doesn't work try calling Lexmark customer support.
Good luck.
Feb 23, 2009 | Lexmark X5495 Printer
HOW TO REFILL LEXMARK X5495 PRINTER
When you try refilling your ink cartridges, you are taking chances that something may go wrong. I would search the web and purchase re-manufactured ink cartridges, which would be less expensive than the new ones from Lexmark.
http://www.ink-refills-ink.com/printer/Lexmark+X5495+Ink/15981/?src=gpsearch&gpprod=Lexmark+X5495&gptype=bulk
http://www.internet-ink.co.uk/lexmark-ink-cartridges-X5495/
Please remember to rate all users who assist you for free :)
Sep 20, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
874 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
