Question about Fisher and Paykel Dryers
Hi my dry had a broken timer knob and the dryer would work if I pushed the knob I got a replacement part but dont know how to rewire it agen and the part looks different the old one had T80 on it but this one has T85
  • Fisher and P... Master
  • 7,482 Answers
Your timer switch should come with a wiring diagram.
Check with the supply house you got the timer from and let them make sure you have the right part for your model dryer.
Sometimes the new timer will be different, that is where the wiring diagram comes into play.
I hope this helps
Posted on Oct 01, 2009
I have a Frigidaire gas dryer. First, the timer
check the ignitor element those go bad after long usage... if you see that when you turn the machine on and the ignitor turn red but the flame not start then you need to replace it.
let me know if it help you , if not let me know as well we will keep working on it...
Jan 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
When i push the push knob the dryer will not start...the electric is there i need to know how to repair the push knob
If you are talking about the starting switch "knob", you will not normally repair that, you will replace it.
If you are talking about the timer switch you normally do not repair the timer switch either...replace it.
If you do decide to replace either switch, remove and replace one wire at a time, this will save you problems with the wiring.
Sep 26, 2009 | Crosley CDE6000 Electric Dryer
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
Large knob broke
just push in and turn counterclockwise...now the shaft of timer did not break,,,???
Feb 03, 2009 | Frigidaire FEQ332E Electric Dryer
Removing Timer knob on Kenmore Electric dryer
Normally, to remove the timer knob, simply push in on the timer knob and turn the knob counter clockwise. it should unscrew itself. If it does not, the shaft inside the timer has broken and the shaft simply free wheels so then you need to take a needle nose pliers to hold the shaft and then you can turn the knob or pull it off
Let me know if you have any further questions
Jun 04, 2008 | Dryers
Auto Dry not advancing
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
May 30, 2008 | Kenmore 73952 Gas Dryer
Dryer only starts sporadically
your headed in the right direction. there are contacts inside the timer that have gone bad. the timer is in the console ofcourse. its not hard to replace and replacing it will solve your problem
Nov 25, 2007 | Whirlpool LEB6300 Electric Dryer
Drying time knob broke
You should be able to simply push the new knob right on the switch shaft. If part of the broken knob shaft is on the switch, remove it first before installing the new knob. If you see that the switch shaft is broken off, replace the switch as well. Hope this helps.
Aug 07, 2006 | Hotpoint Aquarius WD63 Front Load...
Open Questions:
Dryers Logo
149 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
