Question about Christie Roadster S+16K DLP Projector
Christie Roadster 16k is about ready for a lamp replacement. Should the air filter be changed at the same time? If so, what's the Christie product number of the filter?
  • 2,237 Answers
Yes. it is recomended to replace the filters whenever the lamp is replaced. if you have a 500w lamp, use filter #003-120118-01; 1000w lamp, filter #003-120117-01; 1200w lamp, filter #003-120116-01.
Posted on Jan 06, 2010
Christie x6
is the /Roadster X6 ? it is work well with dometic UK mains socket Have a good day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited
Aug 13, 2014 | Christie (03-000457-06P) Projector Lamp...
Christie Roadster S12K
2000W Xenon 03-900519-01P
Original lamp USD2000
Have a good day!
Jan 05, 2014 | Christie Projector Replacement Lamp -...
My Christie LX34 looks like the lamp is burned. There is a yellowish tint on about half of the screen. Someone told me it is the prism and not the lamp. Is this correct?
It is not the lamp so don't spend cash on a new one as they are very expensive - it sounds like one of the filters need replaced or another internal problem other than the lamp - if it was the lamp the whole screen would be effected and it would not be localised.
Mar 22, 2011 | Christie LX34 Multimedia Projector
Hi, I have a Christie RoadRunner L6 Projector. When I turn it on the lamp light turns red and it does nothing. This unit does have dual lamps and a lamp replacement lamp light as well. I figured if it was...
I have a Christie RoadRunner L8 that fires up,lamps turn on and about 5 seconds after the lamps fire up it shuts down and both the warning temp. and ready lights flash at the same time. It seems to me it must be a sensor that tells it to shut down thinking that the machine is too hot-all the fans work and all of the filters are clean and it is moving serious air any clue and if so where do I start to look for such items? Thanks in advance Kirk
Aug 16, 2010 | Christie RoadRunner L8 Multimedia...
Invalid lamp ballast id on 16k Christie This happens when the projector is powered up and the on button pushed. The lamp will strike after many tries ie dropping power and re powering once running no...
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a good day!
wheel,
Sep 23, 2009 | Christie Office Equipment & Supplies
Christie error message "Lamp Interlock Fault"
the switch itself may be broken. check continuity.
May 14, 2009 | Christie Roadster X9 Multimedia Projector
Road pro 1500-red fault lite blinks and has no power
unfortunately, this is a projector post. all i can say is that there is an issue with the inverters. return them to the store that you bought them from and get the next size up.
Mar 29, 2009 | Christie DLP PROJECTOR, SXGA+, 14000 ANSI,...
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
How do I change the bulb on a christie lx380 projector
open up the lamp door, unscrew the lamp, remove it, replace it, replace the door.
Dec 01, 2008 | Christie 38-VIV211-01 LCD Projector
Christie lamp explodes
the lamp VIP300w, with Hg
the lamp have the chance to explode,if the lamp used over 2200 hours
you can replace the lamp when it is about 2000 hours
Have a good day!
wheel,
Dec 10, 2007 | Christie Office Equipment & Supplies
Christie Roadster S+16K DLP Projector Logo
232 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
