Question about Mitsubishi WS-55859 55" Rear Projection Television
TV will not come on
I have a Mitsubishi WS-A55 rear projection TV manufactured in March of 2003. When I try to turn on the TV, nothing happens. I unplug it, let it sit for a few minutes, and then plug in. The timer light next to the power button flashes a few times and then goes out. The TV still does not turn on. What is my next step? Thanks!
  • burnsdarin Oct 02, 2009
    The light comes on, flashes twice, and then shuts off.
  • Mitsubishi Master
  • 5,568 Answers
The flashing LED may be telling you the source of the problem; note the relative spacing of the flashes and the number of times it flashes before staying off. The set is trying to tell you where it is sick but I suspect it is related to the power supply; the most common failure point of most modern sets. If you post back here as a 'comment' you won't have to repeat your symptoms.
Posted on Oct 01, 2009
  • Steve Allison
    Steve Allison Oct 02, 2009
    I'm pasting my normal suggestions below which may help you:
    If it just fails to turn on, the main power supply is probably at
    fault and without some technical background and a couple of test instruments,
    you will not be able to do the repair yourself.
    What
    you can do though is; unplug the set, let it stand overnight or at least
    several hours, remove the back panel and look for a separate board with mostly
    larger components on it; it will have a ferrite core transformer on it and
    several larger capacitors which are cylindrical and mounted vertically to the
    board.
    Before touching anything inside, especially on that board,
    allow several hours to be safe since the larger capacitors can hold a painful
    voltage charge for some hours.
    If you see signs of overheating such as discoloration of
    the board material, it may not be repairable but if you can find a part number
    on the board, you might be able to buy the power supply from the manufacturer and install it
    yourself.
    If there are no signs of heat damage to the board, there
    may be companies offering to repair it as a subassembly instead of repairing
    the whole set which could be much more expensive.
    If
    you choose to replace or have it done, the power supply
    still may not be at fault since most
    are capable of switching on and off if a downstream problem is causing an
    overload.
    Good luck-
2 Suggested Answers
  • 418 Answers
SOURCE: My Mitsubishi projection tv WS-A55 video isssue
Colored ghosts (red,green,blue) is convergence bad. If can't adjust from menu, then bad circuits. Call someone for approximate estimate.
Posted on May 03, 2010
Bad Lamp for TV
Can't get a reception with my ws-a55 tv
Feb 15, 2014 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-A55 with a 2-3 error code
SD Tech - I have the error code 22 on my WS-A55. Power light comes on and then quickly shuts off. Looked at circuit board - there was greenish "gunk" on two of the electronic parts on the board in the center (behind the speaker grill) in the area labelled R5A62. Would you be so kind as to post repair instructions and the name of parts seller you mentioned above? Thanks!!!
Mar 17, 2013 | Mitsubishi WS-48315 48" Rear Projection...
YELLOW TINT ON SCREEN MITSUBISHI TV MODEL WS 55313
The WS is a picture tube type rear projection first produced as a 2003 model year set.
A few questions and then a offer if needed.
Did this happen suddenly or after a power loss?
By reboot do you mean the recessed reset button on the front of the set?
I will presume if you turn color off completely the screen is some other color than black and white?
the offer: have you tried the Option menu this set has hidden, I can explain if needed.
Dec 11, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Apr 20, 2010 | Televison & Video
What year is the mitsubishi ws-65809?
My model is the same and on the sticker at the rear of the TV w/ valuable info. states 2001 as the year of manufacturing.
Feb 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Audio but no picture
sound is one circuit ... picture is over 3 thousand. I havent a clue either.
try turning it off and on fast... if see a flash or white flash you have high voltage at least as high voltage collaspes. check your inputs on remote you might be on av 2 or something.
Sep 13, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi ws-a55 2003 model
this set has self diagnosis, try this first to get error codes. Look here or ctechnicians.com to get info
Dec 31, 2007 | Mitsubishi WS-48315 48" Rear Projection...
Mitsubishi WS-55859 projection tv
how many times does it blink does there seem to be a pattern?
try this:
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
Dec 18, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
336 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
