Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
Convergence??? from what i've picked up so far i have a convergence problem of some sort. the blue curves up and down on the left side of the screen. it started a while ago but sometimes it almost goes away. if you tap on the side of the tv it also goes away and sometimes comes back. could there just be something loose?
    President:
  • 4,402 Answers
Loose connection on the convergance amp ic's best to get fix before it causes more problems.
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Posted on Dec 20, 2007
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Red shift to left with curve at bottom
Par 2 = " I do see the convergence chips..."
Par 3 = " I'm not sure where the IC's are...."
Please verify STK part # of IC's on large heatsinks.....
And then I'll give you step-by-step instructions......T.
Nov 19, 2007 | Panasonic PT-47WX53 47" Rear Projection...
The picture looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
Top of picture has distorted curve
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Aug 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Screen has curves
Bad convergence IC's and possibly yoke return resistors located right by the convergence IC's
Craig
May 08, 2009 | Televison & Video
Toshiba 43A9UE convergence problem
Check the resistors right next to the Convergence ICs often 1 or 2 of them go oen when the ICs fail.
Feb 09, 2008 | Televison & Video
Blue Convergence Problem
This is a pain and you have to be carful in doing this fix. Its basically the bulb thats shot, its got that liquid in it so DO NOT BUST IT OR YOU WILL SCREW THE BOARD UP! THen you have to get a new TV
Oct 26, 2007 | Philips 46PP9302 46" Rear Projection...
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
