Question about CyberPower Computers & Internet
I have a cyber power 1350 avr battery backup the red light on back is lit up under light reads wiring fault what does that mean exactly
informatica
  • 1114 Answers
SOURCE: Wiring Fault light
You can download the manual from the link below: http://www.sourceresearch.com/cyberpower/cyberpower-pdf.cfm?PdfPage=625_Manual.pdf The "wiring fault" could be serious, as per manual: "This LED indicator will illuminate to warn the user that a wiring problem exists, such as bad ground, missed ground, or reversed wiring. If this is illuminated, user is advised to disconnect all electrical equipment from the outlet and have an electrician check the outlet to insure proper ground." I would turn the UPS off, unplug all equipment, wait 10 seconds, reset the circuit breaker (if tripped) and turn the unit on. If you still have an issue then it's probably fried! Have you had any thunder storms or electrical power outages recently? Check your house insurance because it may cover a replacement unit. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 14, 2007
nenalex2002
  • 134 Answers
SOURCE: My wiring fault light is on.
the input power is bad (outlet) it could mean your phase and neutral are backwards. What country are you in? If in USA home depot or lowes sells cheap outlet tester that let you know right away what wire is wrong
Alex
www.CAS411.com
Posted on Feb 22, 2009
  • 15 Answers
SOURCE: "On Battery" Alarm Sounds when Power Available.
if this comes sometimes and goes, this means that the power to ups is sometimes deviating from the specific ups input range, hence the ups is rejecting it. mesure the input voltagesand frequency with a multimeter and check whether they match the specified ones in the ups manual. aslo with some ups there are switches that you use to set the input voltages or number of phases in the ups input. check the manual to see whetther your ups has such.
Posted on Oct 25, 2009
pravinbhavsa
  • 348 Answers
SOURCE: The unit is bleeping and the red light flashing
first disconnect the battery power on the ups check charging voltage it should be 13.8vdc for 12v battery if charging voltage is present then you have to replace the battery if not present then chech the charger transformer diodes and capacitor and regulator ic LM317 if faulty replace it
Posted on Mar 08, 2010
  • 1684 Answers
SOURCE: We have a APC Smart
The light pattern indicates the batteries need to be replaced. The typical life of UPS batteries is 2.5 years, after this time the cells will not hold the proper charge. When your power when off last night the UPS would have tried to switch to battery power but it most likely failed after just a few minutes as the batteries shorted. The UPS has a protection circuit that prevents it from starting up properly with dead batteries so you get the flashing lights and the unit shuts off. The batteries are available in most cities from car battery dealers, not like Wal-mart but battery only dealers, just look in the yellow pages for batteries. You can take the old batteries out of the unit by removing the front panel and unscrewing the metal plate just behind the front cover. The old batteries are connected with a wiring harness that plugs in. Just bring the old batteries to the dealer so they can get you the correct replacement part. The new ones should be less than $100 so it is well worth the price compared to a new unit.
I hope this helps, if so please rate our solution.
BuddyMc
Posted on Feb 04, 2011
APC SmartUPS X (SMX1000)- "AVR Relay Weld" error message
I had this exact problem after a major power out: Fault, call support: AVR Relay weld.
I fixed it by resetting the UPS: Remove battery connect at rear of UPS (it is marked, just unplug the bat connect tab). Plug the UPS back in, and then turn on. Let it power up... it will tell you it needs a battery. Next, power it down and unplug. Plug the batter connect back in (see rear). Plug in the UPS.. power up. Presto.. it is reset. If it is NOT reset, there may be a real 'relay weld'.
May 13, 2013 | Computers & Internet
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1350 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1350 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1350 Manual Download
Garmin Nuvi 1350 QuickStart Download
Garmin Nuvi 1350 Webupdate
Garmin Nuvi 1350 Favorites Backup
on May 15, 2010 | GPS
Tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi...
Would you like to back up a copy of your Garmin Nuvi 1350 Favorites and Waypoints?
  2. After a hard reset or loss of data, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
I hope that helps.
My Generac Guardian 15,000 Watt Model 004582 generator is putting out low voltage (about 45V on the 120V side). The trouble lights on the voltage regulator are lit as follows: Regulator light - lit red...
Hi Jake and welcome to FixYa. I am Kelly. Check both CB1 and CB 2 circuit breakers by pushing them to OFF and then back ON. Open the brush block access and then start the unit. You should read voltage at the brushes of 5 - 14 VDC on the terminals of the brushes. If you do not have 5 - 14 VDC at the brushes the probable suspect is the automatic voltage regulator (AVR). If you do have the correct voltages then with the unit OFF.... do a resistance check across the armature coil by reading resistance at the brush block terminals. You should read around 180 Ohms. It can be more or less resistance but for sure less than 500 Ohms. If you do NOT get a resistance reading remove the brush block assy and test the armature directly by reading across BOTH slip rings. You should get the resistance previously stated. If you have resistance then most likely there is a problem with the brushes. (Too short / broken carbon brush / missing spring or a defective terminal.) Without knowing the AVR output voltage and the armature resistance reading at this point it is difficult as to how to advise you to proceed. Let me know the values you obtain for AVR DC voltage at the brushes and actual ARMATURE resistance reading. Make sure you use R x 1000 on the meter. I am having thoughts of maybe a broken wire somewhere inside the control panel also.
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Generac Guardian 100 Amp Transfer Switch...
Tip
Garmin Nuvi 1350 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 15, 2010 | Garmin nuvi 1350 Car GPS Receiver
Tip
Garmin Nuvi 1350 Favorites Backup and Restoration Procedure Models: Nuvi 1200,...
I hope that helps.
Tone alarm goes off and flashes "overload" and on the back "building wireing fault" is lit up
The "Overload" light and alarm is to tell you that the devices connected to the UPS are drawing more current than the UPS can safely provide with battery backup. You should disconnect a few items, and the alarm and overload light will turn off. The "Building wiring fault" light on the back is to tell you that there's no proper ground wire inside the wall outlet that you're using. These two problems are not related to each other.
Mar 04, 2010 | APC Back-UPSĀ® XS 900 (BX900R) UPS System
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
Wiring Fault light
Aug 13, 2007 | Cybernet Systems CyberPower 625AVR...
Computers & Internet Logo
715 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
