Question about Garmin nuvi 255W GPS Receiver
My GPS that is only about 4 days old works fine sometimes but then it will say "Poor satelite reception" and then "none" what do you recommend?
    Brigadier General:
  • 3,006 Answers
Do you live in a an area with plenty of tall buildings/trees around you? Do you live in a valley? GPS units need to "see" plenty of clear sky to work reliably.
Does the problem occur the same whether you're using it in the car or on foot? Many modern cars have solar reflective glass which has a microscopic metal coating and it blocks satnav signals unless a supplementary external satnav antenna is fitted.
If you press and hold the nuvi's signal strength bar on the display for a few seconds you'll get a screen which shows how many satellites the unit is picking up along with a display which tells you how accurately the machine has fixed your position. It won't fix your problem but can help you find out what seems to be wrong.
If you're still having problems and these are not the causes then there's no point in doing anything further: just return it to the vendor for a refund or exchange as they are sometimes faulty straight out of the box.
Posted on Oct 01, 2009
  • 5,568 Answers
GPS receivers need a good 'view' of the sky so they can connect with more than a single satellite; the minimum is normally three and that does not give you the maximum accuracy.
Garmin Nuvi 610 not Acquiring satelites. it was working fine and while driving suddenly said something about poor reception, now nothing
Its sounds like your GPS's internal receiver is broken, you may be able to fix this with a firmware update but it is likely you will have to purchase an external antenna for your GPS to be functional.
Hope this helps!
Dec 10, 2010 | Garmin Nuvi 610 GPS Receiver
LOSS OF SAT/RECPTION MY GPS KEEPS SAYING NO SATELITE RECPTION HOWDO I FIX THE PROBLEM
Check the BAUD and PORT parameters in the manual
Other things that cause this are
damaged SIIRF chip ( never start car engine with GPS plugged in) New mother board exceeds value of GPS
Battery is too low. Charge fully prior to use by USB or AC mains
Poor reception via position inside of car.Move closer to wwindscreen and away from phones.. radio etc.
Please rate my hyelp++++Thanks for using Fixya
May 29, 2010 | Garmin nuvi 310 Car GPS Receiver
First time using my garmin 205W and it only holds satelite service for about 10 minutes
I recommend you replace the firmware and system software using webupdate. Updates in the Nuvi 205 firmware has increased its satellite reception and accuracy.
I hope that helps.
Apr 01, 2010 | Garmin nuvi 205W GPS Receiver
"Poor GPS Reception" error on iPhone Tom Tom GPS
Unfortunately it appears the iPhone's GPS chip isn't up to much as we've all suspected. Some people can get it working while many are reporting, like you, that they get drop outs and poor signal strength errors. This is happening accross all the iPhone Sat Nav apps so it points the finger at the GPS chip itself, especially as many of these people are stating they have dedicated tomtoms and the like that work fine. I've tried Copilot, tomtom and others on the iPhone 3GS and none are able to keep signal long enough to be any good. In fact they are a complete waste of money. It's no suprise Tomtom are releasing a cradle for the iPhone which includes a seperate more powerful GPS receiver...
Aug 27, 2009 | Tomtom GO 930 GPS Receiver
Garmin Nuvi 265 GPS wont recognize satelite
Look near the SN # and press the reset button.
Jun 14, 2009 | Garmin nuvi 265 Car GPS Receiver
Frequent and prolonged loss of satelites
i want help to upgrade my unit to the latesupdate
Apr 30, 2009 | Garmin nuvi 200W GPS Receiver
TomTom 930 says "Poor GPS Reception"
Try to reset device by using a paperclip or similar at bottom of unit...
Mar 16, 2009 | Tomtom GO 930 GPS Receiver
Lost satellite reception
I have the same problem, and so far the only solution is patience. If you are in a cutting, or between tall buildings, and the satellites are low down on the horizon, then it seems reasonable that reception will be between poor and zero. But in wide open spaces mine too sometimes loses the signal. Hang in there, and contact is restored.
LocoTorque
Aug 11, 2008 | Garmin nuvi 200W GPS Receiver
Garmin gps, novi
What do you see if you use it in the open air? Same thing?
Some cars have a metal coating on the windows that works as a sun block, usually french cars. In these cars satellite reception is poor and this can be a reason for bad reception. Sometimes these problems also occur when a cell phone is too close to the gps. The gps does need line of sight to the sky to get a good signal, usually stuck to the windshield is sufficient.
Apr 04, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 255W GPS Receiver Logo
170 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
